Why Is Calculating the Release Height for a Loop-the-Loop So Challenging?
  • Thread starter Thread starter Juntao
The discussion centers around a physics problem involving a small spherical ball rolling down a ramp and around a loop-the-loop. The objective is to determine the height from which the ball must be released to successfully navigate the loop, considering energy conservation principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of conservation of energy, with attempts to set up equations involving potential, translational, and rotational energy. There are questions about the forces acting on the ball at the top of the loop and the role of the normal force. Some participants suggest re-evaluating the radius used for centripetal force calculations and emphasize the importance of algebraic manipulation before substituting numerical values.
There is an ongoing exploration of the problem, with some participants providing guidance on correcting errors and clarifying concepts. A participant has successfully derived a new expression for height, which appears to resolve their initial confusion, but further clarification on terminology and assumptions continues to be discussed.
Participants are considering the effects of friction and the materials involved in the ramp and loop, questioning how these factors might influence the problem. There is also a focus on the definition and implications of the normal force at the top of the loop.
Juntao
I'm going crazy over this problem. I've spent so much time on it that it sux.
I've included a picture for your pleasure.
A small spherical ball of radius r = 2.2 cm rolls without slipping down a ramp and around a loop-the-loop of radius R = 2.7 m. The ball has mass M = 378 g.
a) How high above the top of the loop must it be released in order that the ball just makes it around the loop?
b) Repeat problem (a) for a disk. Find the ratio of the heights h for the two cases.
Okay,I'm just stuck on part a. If I figure that out, rest should be piece of cake.
I know that I'd have to use conservation of energy. The ball starts off with potential energy, and that converts into translational and rotational energy.
So the equation that I've set up is:
mgh=.5MV^2+.5*I*w^2 (equation 1)
where I is moment of inertia
and w is omega.
Since it is a sphere, the I= 2/5Mr^2
So right now I know
m=.378kg
g=9.8m/s/s
r=.022m
but not omega or velocity, but I can calculate those two.
At the top of the loop, there is a normal force and gravity force acting on the ball. So that's 2*mg, or 7.40N.
Centripetal force = m(V^2/R)
Solving that, I get velocity equals 7.27 m/s
Then v=w*r
Using that velocity number, I get omega=330.45/s
So I plugged in all my values into equation 1, solve for H, and I get H=1.43m, but that isn't right. How do I solve this? I think I'm on the right track, but something along the way is screwing me over!
Juntao,
I think your method is basically correct, except for the following errors:
I think the force of gravity is just mg, not 2mg.
centripetal force = m(V^2/R)
I think, since the ball rolls on the inside, the actual radius is R-r, so
[tex] \textit{centripetal force} = \frac {mv^2}{R-r}[/tex]
Solve again for v and ω, and proceed as you did.
I get H=1.43m. Of course, that isn't right.
How can you see this isn't right? I think the correct answer is in the same order of magnitude.
Originally posted by arcnets
Juntao,
Juntao: arcnets has pointed out your main error; do as he suggests!
Let me add two tips:
1) Don't plug numbers (like for m, g, etc.) in immediately; instead, do as much of your work algebraically until the last step. Only plug numbers in at the end. You'll find that lots of things will cancel and that calculations will be easier and less prone to error.
2) Don't forget that you are to find the height above the loop. When the sphere is at the top of its path in the loop, it's really below the level of the top of the loop.
Still figuring this thing out, but I was wondering, when the sphere is at the top of the loop, why isn't there a normal force? So at the top, it only has gravitational force?
Ok, I'm utilizing advice given by arcnets and Doc Al and this is what happens.
centripetal force
mg=(m*V^2)/(R-r)
or v=sqrt[g(R-r)]
I know this equation v=w*r
so w= (sqrt[g(R-r)])/r
Using the conservation of energy:
mgh=.5*m*V^2+.5*I*w^2
goes to
mgh=.5*m(sqrt[g(R-r)])^2+.5[2/5*m*r^2]+((sqrt[g(R-r)])/r)^2
when I simplify all of that, in the end I get:
h=(7/10)(R-r)
so h equal= (7/10)(2.7m-.022m)=1.8746m. My god, it worked! Thank you guys so much, and takes for the tip Doc Al about using algebra. It did make my life simpler.
There IS a normal force. What does "normal" mean in "normal force"?
are you assuming no friction and if not what is the loop and ramp made of and what is that materialsfriction against the ball and the same thing with the ball.:smile:
Let's be clear about terminology. At the top of its path, the sphere has two forces acting on it. Its weight and the "normal force", which is the force that the loop surface exerts on the ball.
This normal force is, in a sense, a passive force: it will be whatever it needs to be to contain the sphere. (Until the loop breaks that is!) In this problem, you are trying to find the minimum energy to have the sphere just make it around the loop. That minimum is when the normal force equals zero. (Any less energy, and it won't make it to the top of the loop.)
Juntao,
one more detail: The h that you calculated ...
[tex] h = \frac{7}{10}(R-r)[/tex]
is the (IMO correct) height difference of the ball's center-of-mass in final and initial state.
Whereas the h in the picture is taken from top-of-loop to initial center-of-mass. So:
[tex] h = \frac{7}{10}(R-r) - r = \frac{7}{10}R-\frac{17}{10}r[/tex]
13K
