Center of mass and external forces in a closed system
The discussion revolves around the concept of center of mass and external forces within a closed system, particularly in the context of a person sitting in a stationary car. Participants explore how internal movements, such as raising an arm or shifting a finger, affect the center of mass and whether these movements can be considered to involve external forces.
  • One participant describes a scenario where they are in a stationary car, questioning how raising an arm changes the center of mass without external forces acting on the system.
  • Another participant suggests viewing the arm as a rigid body and proposes that internal forces, such as muscle contractions, are responsible for the movement.
  • A hypothetical scenario involving a fly in the car is introduced, questioning whether the wing muscles would be considered external forces.
  • Discussion includes the complexity of forces acting on the fly's wings and the importance of analyzing internal forces rather than the entire system.
  • One participant questions the definition of a closed system, suggesting that internal forces can still be considered external depending on the perspective taken.
  • Another participant argues that the system must include the Earth, as it interacts with the car, thus affecting the center of mass.
  • Concerns are raised about defining closed systems, with some arguing that only the entire universe could be considered a truly closed system.
  • A later reply posits that in a weightless environment, the act of raising a finger would cause the car to move oppositely, maintaining the center of mass stationary.
  • One participant reflects on the implications of internal forces on the overall motion of the car and the person within it.
Participants express differing views on the definition of a closed system and the role of internal versus external forces. There is no consensus on how to interpret the effects of internal movements on the center of mass within the context of a closed system.
Participants highlight limitations in their definitions of closed systems and the assumptions made about internal and external forces. The discussion remains open-ended regarding the implications of these definitions on the behavior of the center of mass.
whozum
I'm sitting in my car on a flat road while it is stationary. The only forces acting on my car for this exercise are gravity and the normal force, which add up to give no net external force on my vehicle and me. My center of mass is at a fixed point somewhere in the vehicle, and according to the principles of Newton's laws, this fixed point should not move unless an external force outside of the car acts on the vehicle. If I was to raise my right arm, or do so little as to move my finger, my center of mass surely enough has changed its position, however no external forces have taken any effect.
How is this explained?
Think of your arm as being a rigid body. And think of your tendon as being a hydrolic piston. That piston extends, and is connected to a part of your arm. It in turn raises your arm as well.
When looking at your whole body, you have made your free body diagram so that it makes the forces rasiing your arm internal. The "outside force" on your arm is your tendons/muscles flexing and contracting. So there is a net force on it, and it does raise. You also have a force on it when you lower your arm, becase your muscles retard gravity from allowing them to swing down fast and hurt yourself.
If you are worried about the forces on your arm, then your free body diagram should include ONLY your ARM.
Well my arm was just the hypothetical object, but anything else could be used instead. I remeber a long time ago someone asked a simliar question with regards to a fly flying around in the car. Would the wing muscles be the external force then?
Well, you have a wing. What are the forces acting on its wing. I believe its motion is quite complicated, it swings up/down and back/fourth simultaneously. So consider it ball and socket connected at the juncture between the body of the fly and the wing. It will support half the weight of the fly, so its got a force of w/2 at that point. Its very light weight compared to the body of the fly, so you can ignore the weight of the wing itself. Its gota overcome that w/2 force to stay up, and hover. That will act at the center of pressure of the wing. ( I THINK). And create a moment about that hinge point. But that moment is balanced by the other wing creating an equal and opposite moment on the other side of the fly since its symmetrical. And the movement of the wings has to be driven by a tendon or something of that nature, that makes the wing move up and down. Again, you could think of it like a hydraulic piston connected from the body to the wing, that forces up/down motion of the wing.
If you try looking at the whole fly in the car, it does you no good. All the driving forces are now internal to the fly. That tells you nothing. You have to "disect" the fly to see the forces where you are concerned.
(actually, the net torque on the whole fly is zero, which is what I wrote earlier; however, the torque on the wing is not zero, and results in it rotating up and back).
So a closed system isn't necessarily a literally CLOSED system, for example although you could put the car and me and the fly in a box and look at it from the outside, a force within the box can still be considered external?
I don't understand why you are calling it a closed system. I thought a closed system is one where energy is not exchanged with the environment. Maybe someone more qualified can tell you that. I am just looking at the places of interest by segmenting the body and making the appropriate free body diagrams to see what are the internal forces at work.
The way I'm looking at it is in reference to Newton's laws and the inability of a center of mass to move without an external force. For example the popular airplane that blows up midflight is another example. If it breaks into 3 pieces the center of mass of the plane will continue along the same path that it was going before the explosion purely because it was a closed system.
How is what explained? You define your closed system incorrectly then you're surprised by the result. The system includes the Earth which is pushing up on your car. The act of raising your finger caused you to push down on the Earth which had to move in the opposite direction to compensate. The center of mass of the real system did not move.
Isn't a system anything you define it to be? So if I did define the system the way I did, then the external force acting on the car would be the normal force from the earth?
What if the motion was horizontal? for example shifting my finger to the right. Would it then be the friction force stopping the car from moving to the left?
Yes, a system is anything you want it to be ... BUT ... you specified a closed system which means it's not interacting with anything else. The car is interacting with the Earth and so the Earth must be included as part of your CLOSED system. :smile:
Then along those lines isn't the only closed system the entire universe? So other closed systems that are mentioned are usually for ideal purposes or mental exercises/
That's a dubious conclusion. Your example was blatant in that you had to apply a force to achieve a particular result and neglected an integral component in the force balance. Had you set up your car in a weightless environment (with adequate heating and air supply, of course!) you could have regarded that as a closed system -- and clearly seen that the act of raising your finger caused the car to move oppositely with the center of mass remaining stationary.
Clearly, closed systems can be defined for many situations and when something appears to "violate" basic physics that should be a clue you need to reassess your particular definition of "closed system."
This is something I was going to ask about but I understood clearly in my head, however it raises the issue which goes along with your other statements: moving my finger would move the car, and since it was a force, wouldn't the me-car system will have a final velocity different to the initial velocity?
I lost my train of thought..
  • · Replies 24 ·
  • · Replies 31 ·
  • · Replies 77 ·
