Grade 12 Physics - mass on an inclined plane (different question)
The discussion centers on calculating forces acting on a block weighing 80N on a 20-degree inclined plane, with static and kinetic friction coefficients of 0.25 and 0.15, respectively. To prevent the block from slipping down, the minimum force required is 46.15N, while the force needed to initiate upward movement is also 46.15N. For maintaining constant velocity up the incline, the force required is 37.76N. The confusion between the minimum forces for static and kinetic scenarios is clarified by understanding the direction of frictional forces.
  • Understanding of Newton's laws of motion
  • Knowledge of static and kinetic friction coefficients
  • Ability to resolve forces on inclined planes
  • Familiarity with trigonometric functions in physics
  • Study the principles of static and kinetic friction in detail
  • Learn how to resolve forces on inclined planes using free-body diagrams
  • Explore the impact of different angles on frictional forces
  • Practice problems involving forces on inclined planes with varying coefficients of friction
Students studying physics, particularly those focusing on mechanics, as well as educators looking to clarify concepts related to forces on inclined planes.
an_mui
A block weighing 80N rests on a plane inclined at 20 degrees to the horizontal. The coefficient of static friction is 0.25, while the coefficient of kinetic friction is 0.15.
a) What is the minimum force F, parallel to the plane that will prevent the block from slipping down the plane?
b) What is the minimum force F that will start the blocking moving up the plane?
c) What force F is required to move the block up the plane at constant velocity?
a) I am confused about the difference between question a and b? I don't know how to determine the minimum force that will prevent the block from slipping down the plane.
b) my equations
x-direction: Fapplied - Ffriction - mgsin theta = 0
y-direction: N - mgcos theta = 0
Ffriction = usN
Ff = us (mg cos theta)
Fapplied = us (mg cos theta) + mgsin theta
Fapplied = 18.79 + 27.36 = 46.15 N
N = mgcos theta
c)
Ffriction = ukN
Ff = uk (mgcos theta)
Fapplied = uk(mg cos theta) + mg sin theta
Fapplied = 10.4 + 27.36 = 37.76N
Please correct me if i made any mistakes
actually for a:
the answer i got is:
F = mg (sin theta - ucos theta)
but other people got different answers... could someone please help me out?
Your answers for a) and b) are correct.
For c), check your value for the kinetic friction. It should be about 11.3.
The difference between a) and b) is in the direction that the friction acts.
Friction always opposes motion, or tendency to move.
If the block is moving in one direction, then friction is acting in the other direction.
If the block is static, then in what direction would it move if there were no friction ?
The actual friction would then act in the opposite direction to that motion.
  • · Replies 16 ·
  • · Replies 68 ·
14K
