Home Power Generation - Can You "Sell" Energy Back to the Grid?
The discussion revolves around the feasibility of using a bicycle to generate electricity that could be sold back to the power grid. Participants explore the concept of home power generation, particularly focusing on human-powered systems and their potential to contribute to energy production.
  • Some participants suggest that it is theoretically possible to generate electricity using a bicycle, but the amount produced would likely be insufficient for practical use.
  • One participant mentions that even a fit individual might only generate around 200 watts for a limited time, which may not justify the effort.
  • Another participant raises concerns about grid regulations, noting that power companies may have restrictions on the minimum amount of electricity that can be transmitted back to the grid.
  • There are discussions about the efficiency of coupling small generators to the grid, with some suggesting that losses would dominate for low-output systems.
  • Participants reference the idea of using bicycles in gyms to generate power, suggesting that this could offset some electricity costs.
  • One participant recalls a book discussing various applications of pedal power, indicating that human-powered systems have been used for diverse tasks.
  • There is mention of the need for the electricity fed into the grid to match specific frequency and phase requirements.
Participants generally agree that while the concept of using a bicycle to generate power is interesting, there are significant practical limitations and uncertainties regarding the feasibility and efficiency of such systems. Multiple competing views remain on the potential for human-powered electricity generation.
Limitations include uncertainties about the actual power output from human effort, the efficiency of energy transfer to the grid, and the regulatory framework governing energy sales back to the grid.
rickrock
Hi,
I am from the uk and very interested in home power generation. I am aware that there is a system that you can install in the home which will 'sell' excess power back to the grid if for example you are running a wind turbine which produces more electricity than your home requires.
In principle, could you setup a bike whereby pedalling will 'sell' energy back to the grid? I know that this energy production would be very small, but when I look at even medium sized wind turbines, it seems that the energy required to make the necessary revolutions of the wind blades turning a dynamo could be done using a bike chain/peddle setup by a reasonably fit person? I say it seems so but I am guessing I am making a grave miscalculation here although I'd like someone toexplain to me why.
However as I said, would it in principle be feasible to make such a setup with a modified bike to 'sell' power back to the grid, no matter how small? What would be the main technical difficulties in making such a system? If anyone knows of some relevant resources I'd appreciate it.
In principle you could generate electricity using a human run bike wheel but you wouldn't generate enough electricity to power a light bulb. Practically unfeasible.
Have you ever used an exercise bike, rickrock? Most electronic ones tell you how many watts you are generating. If you're Lance Armstrong, you may be able to generate 200w for a few hours, but even that isn't enough to be worth doing.
I think our local power company (PG&E) has restrictions on how little you are allowed to transmit back into the power grid, but I'm not certain about that. I also think that coupling power back into the grid is not generally possible at 100% efficiency, so the losses would likely dominate for a small generator like 100W. I googled PG&E and Cogeneration, and got to this fairly useful page:
http://www.pge.com/suppliers_purchasing/qualifying_facilities/
BTW, speaking of wind turbines and power generation, I always wondered how they combined the power output from multiple windmills spinning at different speeds (due to wind speed variations). I wrote a letter to our local newspaper's answer column, and got a very interesting reply. It turns out that all the windmills in a farm will spin at the same speed -- they are locked to the 50/60Hz power grid, and they contribute varying amounts of power to the grid, based on the local wind speed. We have large windmill farms nearby east of Livermore, California, and when we drive by them now, it's obvious that they are all locked together. Pretty interesting.
rickrock - why not just start this up in your own local gym and now people would pay you to use the bicycles and you might save 5-10% of the electric bill from the generated power.
We as humans don't really generate much power. Some science show was talking about having pedals in an electric car so the passengers could generate electricity and exercisd. Too bad it could easily be outperformed with a photovoltaic cell on top the car, and now you'd really want one of those gaudy air fresheners hanging from the rear view mirror. :smile:
If you don't believe us hook a car alternator up and have it power a regular 60W automotive headlight (with the alternator you'll need an inital 12V battery hookup to get it generating power unless its a one-wire alternator). If you're in good athletic condition, maybe 3-4 hours for less than 1/4 a kWh, which at 10 cents/kWh is just over a couple pennies American money.
The concept of using a bicycle to generate power is really not that far fetched. I remember reading a book called Pedal Power, that described pedalling a bicycle to power such diverse applications as a drill press, washing machine, a grinder, TV/VCR, generator, to saw wood, pump water, split logs, and press cider.
Here is another related link on human power
I remember Ivan saying that a human body can create around the area of 100W.
Lightbulb here i come!
Im not sure, but i think to enable the grid to accept electricity, it may have to be a certain frequency/phase i think.
I like the idea for the gymnasium though :-)
I have always dreamed of hooking up the kids game system to a battery and a bike. If they want to play they have to charge up the battery first. Get their exercise and play as well.
I know of someone who did that with the TV set. The kids quickly learned to weed out the shows that they didn't really care for. (They could 'bank' the power in batteries, so they didn't actually have to be pedalling while watching.)
  • · Replies 74 ·
11K
  • · Replies 46 ·
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 24 ·
