| Thread Closed |
Finding the direction vector with only direction angles.. |
Share Thread | Thread Tools |
| Nov2-05, 08:04 PM | #1 |
Hey everybody! Thanks for any help!
If I am told a line has direction angles of 60, 45 and 60 and passes through the point (-2, 1, 3). How would I go about figuring out the symmetric equations of the line.. Relatively simple question but I am a tad confused. HELP! THANKS AGAIN! |
| Nov3-05, 08:44 AM | #2 |
If [tex]\theta[/tex], [tex]\phi[/tex], and [tex]\psi[/tex] are the "direction angles", then [tex]cos(\theta)[/tex], [tex]cos(\phi)[/tex], and [tex]cos(\psi)[/tex], the "direction cosines", form a unit vector in that direction.
cos(60)= 1/2, cos(45)= [tex]\frac{\sqrt{2}}{2}[/tex] so a unit vector in the direction with direction angles 60, 45, 60 (degrees- it would be good idea to say that explicitely!) is [tex]\frac{1}{2}i+ \frac{\sqrt{2}}{2}j+ \frac{1}{2}k[/tex] and parametric equations for a line in that direction, passing through (-2, 1, 3) would be [tex]x= \frac{1}{2}t- 2[/tex], [tex]y= \frac{\sqrt{2}}{2}t+ 2[/tex], [tex]z= \frac{1}{2}t+ 3[/tex]. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding the direction vector with only direction angles..
| Finding the direction of the resultant vector of three vectors? | Introductory Physics Homework | 10 | ||
| vector direction | Introductory Physics Homework | 3 | ||
| Direction of a 3D Vector | Introductory Physics Homework | 4 | ||
| Direction of acceleration when direction of moving particle changes by 90 degrees? | Introductory Physics Homework | 6 | ||
| What is the correct method of finding the direction of a Vector | Introductory Physics Homework | 5 | ||
