How can I find the mechanical energy lost due to friction?
  • Thread starter Thread starter johny_doe
    Force
The discussion revolves around calculating the mechanical energy lost due to friction for a block sliding down an incline. The problem involves a 5.0 kg block that slides 2.5 m down a 30-degree incline in 2.0 seconds, with participants exploring the relationship between potential energy, kinetic energy, and frictional forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods to find the energy lost due to friction, including calculating kinetic energy and considering forces acting on the block. Some question the accuracy of velocity calculations and suggest using acceleration to determine frictional forces.
The discussion is active, with multiple interpretations being explored regarding the calculation of energy lost due to friction. Some participants have offered guidance on focusing on the forces acting on the block and developing equations of motion, while others have pointed out potential errors in the original poster's calculations.
Participants are working within the constraints of the problem's parameters, including the mass of the block, the incline angle, and the time of descent. There is an emphasis on using Newton's laws and the given motion data to derive unknowns.
johny_doe
Find the mechanical energy lost due to friction:
Starting from rest a 5.0kg block slides 2.5m down a rough 30.0 degree incline in 2.0s.
I know that the PE is 61.3 J. I keep on getting about -57 J when I try to find the mechanical energy lost due to friction but the answer is actually -45 J. Does anyone know what I am doing wrong. This is how I was trying to find it:
W = KEf - PEi
= .5mv^2-mgy
= .5(5.0kg)(2.5m/2.0s)^2 - (5.0kg)(9.8)(sin30*2.5m)
Forget the PE.
You are asked to find the energy lost due friction. So you have to find the friction, that's all.
The block is sliding down a plane. What are the forces acting on it ?
Use Newton's 3rd law to devlop an eqn of motion.
You can find out the unknowns in this eqn by using the data about motion already given.
Your velocity calculation is wrong. You are calculating the average velocity, but you want the final velocity for the kinetic energy.
So instead of s/t, you'd want 2s/t (from S = t(u+v)/2). I get 45.6J.
The other method is to determine the acceleration of the block, then the frictional force, then the work. I don't exactly understand Fermat's suggestion. Actually, I think he was suggest this approach, that you use the acceleration to find the frictional force.
I'll clarify my approach. :smile:
Fermat said:
...The block is sliding down a plane. What are the forces acting on it ?
There are two forces. The slope component of the mass, Fm say, acting down the plane and the friction force, Fr say, acting up the plane. The net force on the body is Fnet = Fm - Fr.
Fermat said:
...Use Newton's 3rd law to devlop an eqn of motion...
i.e F= ma
or
Fnet = ma
Fermat said:
...You can find out the unknowns in this eqn by using the data about motion already given.
You can do this bit now, yes ?
  • · Replies 19 ·
  • · Replies 19 ·
