Height of Radio Tower: Using the Law of Sines
  • Thread starter Thread starter StarkyDee
    Trig
The discussion revolves around estimating the height of a radio tower using the Law of Sines, based on measurements of angles of elevation from two different heights. The problem involves trigonometric relationships and right triangles.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the setup of two right triangles based on measurements taken from different heights. There are attempts to express the relationships between the height of the tower and the distances involved using the Law of Sines. Questions arise regarding the correct diagramming of the second triangle and the relationships between the angles and sides.
Some participants have provided calculations and insights into the relationships between the angles and sides of the triangles. There is an ongoing exploration of how to properly visualize the problem with diagrams, and some participants express gratitude for clarifications received from others.
Participants mention difficulties with diagramming and using LaTeX for mathematical expressions. There is also a reference to the constraints of file size when sharing diagrams.
StarkyDee
2 boys desiring to estimate the height of a nearby radio tower measured the angle of elevation at their house and found it to be 52 degrees. they took a second measurement from the second-story window and found the angle of elevation to be 44 degrees. they next measured the window to be 24 feet above the ground. to the nearest foot, what is the height of the radio tower?
Law of sines:::
i can't figure out how to use new latex for this ...
sin a / a = sin b / b = sin c / c
thanks
A diagram of what you mean would really really help.
I'm pathetic with Latex as well, so bear with me.
Okay, call the height of the tower 'a' and the distance along the ground toward the tower 'c'. You need to think of a right-angled triangle with base 'c' and opposite leg 'a'.
When the boys take their measurements from the second-floor window, think of a different triangle, this one with opposite side (a - 24)ft in height. You may notice that the base 'c' does not change between these two locations.
Therefore
a/(sin 52) = c/(sin (90 - 52)) = c/(sin 38)
and
(a - 24)/(sin 44) = c/(sin(90 - 44)) = c/(sin 46)
Since
a/(sin 52) = c/(sin 38)
a = c(sin 52)/(sin 38)
And also, since
(a - 24)/(sin 44) = c/(sin 46)
a = c(sin 44)/(sin 46) + 24
So, now we know that
c(sin 44)/(sin 46) + 24 = c(sin 52)/(sin 38)
And that
c = 24/[(sin 52)/(sin 38) - (sin 44)/(sin 46)]
From before, we found that
So substitute your value for c into this equation and that will yield your answer.
AD- thanks for the calculations. but i still don't understand how to diagram the second triangle? the first triangle is a right triangle,
i think i have the first triangle right..but where does the 2nd one go?
I've drawn a diagram in paint, but it is not attaching because it is apparently too big, despite the fact that I've gotten the file size down to 9KB. Perhaps you could PM me your e-mail address and I can send it to you that way.
Did you get the e-mail, Starky? Or did it not go through?
oh ok! thanks so much for the graph, now i understand what your talking about with that diagram. i can't believe i couldn't figure that out- it's so easy now that i look at your picture- thanks again andrew.
sincerely,
~david
  • · Replies 28 ·
13K
