Uniformly Distributed Current in a Wire: Question Explained
The discussion focuses on calculating the magnetic field inside a straight wire with a radius R carrying a uniformly distributed current I. The key equations derived include B*2πr = μi_inside, where i_inside is determined using the formula i_inside = I*(πr^2)/(πR^2), leading to i_inside = I*r^2/R^2. This relationship arises from the uniform distribution of current across the wire's cross-sectional area, allowing for the calculation of current density as I/πR^2.
  • Understanding of Ampere's Law
  • Familiarity with magnetic fields and current density
  • Basic knowledge of calculus for area calculations
  • Concept of uniform current distribution in conductors
  • Study Ampere's Law in detail
  • Learn about magnetic field calculations in cylindrical conductors
  • Explore current density and its implications in electrical engineering
  • Investigate the effects of varying current distributions on magnetic fields
Electrical engineers, physics students, and anyone interested in electromagnetism and magnetic field calculations in conductive materials.
leelee
ive posted this in the other forum, but haven't received a reply, so trying again :)
Question:
-straight wire with radius R, carrying current I
-current is uniformly distributed across the cross sectional area of wire
-calculate the magnetic field inside wire as function of distance r from the center of the wire
In the solution, there is a picture of the cross section of the wire, and the current is going into the page, ie X.
there is an imaginary circle, "amperian loop" with radius r, inside the wire.
then, B*2*pi*r = u*i_inside (equation 1)
then i_inside = I*(pi*r^2)/(pi*R^2) = I*r^2/R^2 (equation 2)
This i don't understand. I know it something to do with the fact that current is uniformly distibuted, but how to get equation 2?
Is it just a ratio?
Thanks!
It's given that current is uniformly distributed across the cross section of the wire. So, if you want to find the current density(current per unit cross sectional area), it will be [tex]\frac{I}{A}[/tex] which is [tex]\frac{I}{\pi R^2}[/tex].
From this current density, how will you find the current inside a cross-sectional area with radius 'r'. Can you see how equation 2 follows?
Ah, yes i understand now. Thanks Siddharth!
