What Does the -ic Suffix Indicate in Chemistry?
The suffix -ic in chemistry indicates a higher oxidation state of multivalent transition metals, contrasting with the -ous suffix, which denotes a lower oxidation state. For example, ferric corresponds to iron (III) or Fe3+, while ferrous refers to iron (II) or Fe2+. Similarly, plumbic is Pb4+ and plumbous is Pb2+, while cupric is Cu2+ and cuprous is Cu+. The -ic and -ous suffixes also apply to acids derived from -ate and -ite anions, respectively.
  • Understanding of oxidation states in transition metals
  • Familiarity with chemical nomenclature rules
  • Knowledge of common polyatomic ions
  • Basic chemistry concepts related to acids and bases
  • Study the differences between -ic and -ous suffixes in chemical nomenclature
  • Learn about the properties and reactions of transition metals
  • Explore the relationship between oxidation states and acid-base chemistry
  • Research common polyatomic ions and their corresponding acids
Chemistry students, educators, and professionals seeking to deepen their understanding of chemical nomenclature and oxidation states in transition metals.
Math Is Hard
Staff Emeritus
What does the ic suffix mean in compound names? For instance ferric, plumbic, cupric? I'm guessing it has something to do with the charge on the metal ion?
I have some nomenclature rules from my teacher but this isn't covered. Thanks.
-ic is the coplement to -ous. -ic represents the higher oxidation state; -ous the lower for multivalence transition metallic ions
ferric is equivalent to iron (III) or Fe+3
ferrous is equivilent to iron (II) or Fe+2
plumbic = Pb+4
plumbous = Pb+2
cupric = Cu+2
cuprous = Cu+
The -ic /-ous suffixes are also used for acids of -ate (1 higher oxidation state than -ite),-ite anions respectively
eg, the nitrate ion (NO3-) and nitric acid: HNO3
nitrous ion (NO2-) and nitrous acid: HNO2
or phosphate ion (PO4-3) and phosphoric acid: H3PO4
phosphite ion (PO3-3) and phosphorous acid: H3PO3
Thanks, Cesium!
  • · Replies 24 ·
26K
15K
36K
