Thermodynamics - Ideal Diatomic Gas
  • Thread starter Thread starter ChronicQuantumAddict
    Gas Thermodynamics
The discussion revolves around the behavior of an ideal diatomic gas undergoing two types of reversible compressions: isothermal and adiabatic. The gas is initially at a specified volume, pressure, and temperature, and participants are tasked with calculating various thermodynamic properties following the compression.
  • Participants explore the relationships between pressure, volume, and temperature for isothermal and adiabatic processes. Questions arise regarding the implications of constant temperature on internal energy and the calculations of work done and heat transfer.
Some participants have offered insights into the calculations for the isothermal process, discussing the relationships between pressure, volume, and internal energy. Others express confusion about the implications of constant temperature on internal energy and seek further clarification on the formulas involved.
There is an emphasis on understanding the properties of ideal gases and the specific heat capacities involved. Participants are also navigating the constraints of the homework assignment, which requires detailed calculations without providing complete solutions.
The question is as follows:
An ideal diatomic gas for which cv = (3/5)*R, where R is the ideal gas constant, and occupies a volume V= 2 meters^3, at a Pressure Pi= 5 atm and temperature Ti = 20 degrees celsius (= 293 K). The gas is compressed to a final pressure of Pf = 12 atm. Calculate the final volume Vf, the final temperature Tf, the work done dW, the heat transferred dQ, and the change in Internal energy dU for the following:
a). a reversible isothermal compression
b). a reversible adiabatic compression
i know in the adiabatic process, dQ = 0, and in the isothermal dT = 0. Where do i take it from here? :confused:
anyone please?
The first one is fairly straightforward. Think PV=nRT. If T is constant, what does that tell youi about PV at all times? That should give you Vf. What is U at intial and final volumes? What is W in terms of P and [itex]\Delta V[/itex]? That should give you W. What is the relationship between U, Q and W? That will give you Q.
For the second part, it is more complicated. You have to use the adiabatic relationship:
[tex]PV^\gamma = constant[/tex]
where [itex]\gamma = C_p/C_v[/itex]
What is [itex]\gamma[/itex] here?
What is the expression for W?
How is W related to Q and U?
AM
Please HELP!
i am stuck with the internal energy for part a) isothermal process.
here is what I've done so far. since its isothermal:
P1*V1 = P2*V2​
and thus,
V2= (P1/P2)*V1 = 0.8333333 m^3
For isothermal, Ti = Tf = T = constant = 293.15 K
W = -nRT*(Integral: Pi to Pf) (dP/P) = -nRT*ln(P2/P1) = nRT*ln(P1/P2)
thus W = -2.134 * 10^6 J, work done on the system
Now, for U i am stuck. i keep reading in the book, that for an ideal gas U only depends on T, and they give me this formula.
U - U_0 = dU = Cv*dT, where Cv is the specific heat at constant volume. but volume is not constant in this problem, and also, this leads to an integral with dT and for isothermal dT = 0
If this is true, then the integral yields a constant U
and that means U_final = U_initial, but that still doesn't tell me what U is.
Anything further? where am i going wrong?
please help, need to turn this in tomorrow and I am stuck
P1*V1 = P2*V2​
and thus,
U is the internal energy due to kinetic energy of the molecules. If you keep the volume constant and increase the temperature, the gas does no work. So the increase in internal energy is equal to the heat input. Since the heat flow is just the heat capacity of the gas at constant volume multiplied by the change in temperature, [itex]dU = nC_vdT => U = \int dU = \int nC_vdt = nC_vT[/itex].
So [itex]U = nC_vT[/itex] (T in K).
AM
understood now, thanks very much AM
11K
