How Do I Obtain Specific Solutions for Linear Diophantine Equations?
  • Thread starter Thread starter totoro
    Homework Mean
The discussion revolves around solving a linear Diophantine equation represented as 893x ≡ 266 (mod 2432). Participants are exploring the methods to find specific integer solutions for the coefficients u and v in the equation 893u - 2432v = 19, derived from the problem.
  • Participants discuss the calculation of the greatest common divisor (gcd) and its implications for the existence of solutions. There are inquiries about the derivation of specific values for u and v, and how to transition from negative to positive solutions. Some participants question the correctness of the values provided in the textbook.
The discussion is active, with participants sharing their calculations and questioning the validity of the textbook answers. There is a focus on understanding the relationships between the coefficients and the implications of their signs. No consensus has been reached regarding the correctness of the solutions.
Participants note that the gcd of 893 and 2432 is 19, which divides 266, indicating that solutions exist. There are also concerns about the formatting of mathematical expressions in the discussion.
totoro
i need help with this question
893x=266(mod 2432) ,= mean congruence
fisrt i find gcd(893,2432)=19
then i need to find u,v for 893u-2432v=19
the u and v i found is -49 and -18
but the answer here in my book is 79 and 29
after calculating, i found that both the answer are correct. my question is how to get 79 and 29?
thanks.
If the problem is "893x=266(mod 2432)"
how could the answer be "u= 79 and v= 29" OR "u= -49 and v= -18"?
Where did u and v come from? What happened to x?
first i use this method to find the gcd of (893,2432).that is
2432=893(2)+646
893=646(1)+247
646=247(2)+152
247=152(1)+95
152=95(1)+57
95=57(1)+38
57=38(1)+19
38=19(2)+0
from here i found the gcd is 19
then 19 can divide 266, therefor it has a solution
if i reverse all the step above, i will get
2432(18)-893(49)=19
from this 893x=266(mod2432)i can change to 893x-2432y=266
therefor this formula 893(-49)-2432(-18)=19 should multiply by 14 to get the formula same as above. with this i can get x later, but the problem is that i get -49 and -18 and not 79 and 29.
totoro,
I think the answer in the book is wrong. Because
[tex] 893\cdot79=19(\mod{2432})[/tex]
[tex] 893\cdot29=1577(\mod{2432})[/tex]
They do not work. Why do you think they are correct?
(Why does it make these spaces before mod? How can I TeX it better?)
the formula i get is 893u - 2432v = 19. with euclidean algorithm i get 893(-49) - 2432(-18) = 19. i get negative numbers (u,v) = (-49,-18). how can i change it to a positive numbers like (u,v) = (79,29)?
Sorry, I can only help you if you answer my question.
10K
14K
