How to Find Distance of 1 kg Object After Explosion in Projectile Problem
  • Thread starter Thread starter formulajoe
The problem involves a projectile that explodes into two fragments at the peak of its trajectory. The original projectile has a mass of 3 kg and is fired at a speed of 120 m/s at an angle of 30 degrees. After the explosion, one fragment weighs 1 kg and the other weighs 2 kg. The 2 kg fragment lands directly below the explosion point after 3.6 seconds, and the task is to find the distance from the firing point to where the 1 kg fragment lands.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using conservation of energy and momentum to analyze the explosion and subsequent motion of the fragments. There are questions about which velocity component to use for calculations, and some participants express uncertainty about the calculated velocities.
Participants are exploring different methods to solve the problem, including conservation of momentum in both x and y directions. Some have provided calculations for the velocities of the fragments, while others are questioning the validity of those calculations. There is no explicit consensus on the correctness of the approaches or results yet.
There are assumptions regarding the conservation of momentum and energy, and the discussion includes considerations of the projectile's motion before and after the explosion. The problem's constraints include the specific masses of the fragments and the time it takes for the 2 kg fragment to reach the ground.
formulajoe
a projectile of mass 3 kg is fired at 120 m/s at an angle of 30 deg. at the top of the trajectory the projectile explodes into 1 kg and 2 kg fragments. the 2 kg fragment lands directly below the point of explosion. it takes 3.6 sec for the 2 kg object to reach earth. find the distance between the point of firing and the point at which the 1 kg object strikes the ground.
Ive figured out where the 2 kg object lands to be 634 meters from the point of firing. The top of the trajectory is 184 meters up. When the object explodes the 2 kg object takes some of the KE because it only takes 3.6 sec to reach the ground. So using conservation of energy i set up an equation like this
1/2(3kg)(v^2) = 1/2(2kg)(33.5^2) + 1/2(1 kg ) v1^2.
I'm trying to find v1 so i can find the distance. but i don't know what to use for v. do i use the 120 m/s or do i use the horizontal component of the velocity which is 104 m/s?
Use the conservation of momentum, realizing that the velocity of the projectile at the point of the explosion is purely in the x direction. The momentum of the 2kg piece after the explosiotn is purely in the y-direction. The sum of this momentum and the y-momentum of the 1-kg piece must be 0. The x-component of the momentum of the 1 kg piece is equal to the original x-momentum of the unexploded projectile. With the velocity components of the 1 kg piece and its initial position, the rest of the problem is just a projectile motion exercise.
using conservation of momentum i get the velocity of the 1 kg piece to be 247 m/s.
i did (3kg)(104m/s) = (2kg)(33.5) + 1kg(v).
the 104 is the x component of the velocity. the 33.5 is the y component of the 2 kg piece. this leaves the velocity of the 1 kg piece 247. is that right? that sounds too high.
Remember to treat momentum as a vector quantitiy:
Just before the explosion, the momentum of the projectile is 3kg*120m/s*cos(30 degrees) in the x direction. Since the 2 kg piece goes straight down, conservation of momentum in the x direction gives: 3*120*cos(30) = 2*0 + 1*v1,x. Solve that to get the x-velocity of the 1 kg piece.
For the y-momentum, just before the explosion v3,y = 0. v2,y comes from the kinematic data given (you already found this velocity to be about -33 m/s (note the negative sign, implying the initial velocity is down). Conservation of momentum now gives: 0 = 2*v2,y + 1*v1,y. Solve that to get the y-velocity of the 1 kg piece.
Then use that info to find the landing point.
  • · Replies 38 ·
  • · Replies 38 ·
  • · Replies 30 ·
