But why is that?Why Doesn't Nitrogen Form NCl5?
The discussion revolves around the question of why nitrogen does not form NCl5, in contrast to phosphorus which can form PCl3 and PCl5. Participants explore concepts related to hybridization, molecular geometry, and the octet rule, as well as the properties of molecules like NH3, H2O, and CH4.
  • Homework-related
  • Some participants suggest considering the size difference between phosphorus and nitrogen as a factor in nitrogen's inability to form NCl5.
  • One participant defines a "non-conformist" atom in the context of the octet rule, noting that both phosphorus and nitrogen are non-conformist, but with different bonding capabilities.
  • Another participant emphasizes the importance of Lewis structures in understanding molecular formation.
  • Some argue that nitrogen's smaller size prevents it from accommodating five chlorine atoms around it, which is necessary for NCl5 to exist.
  • Participants discuss the polar nature of NH3 and H2O compared to the non-polar nature of CH4, attributing this to the uneven distribution of electron density and molecular shape.
  • There is mention of hybridization types, with some noting that nitrogen lacks d orbitals necessary for certain hybridizations that allow for more bonding.
  • One participant points out that nitrogen does not have enough orbitals to accommodate five ionic clouds, unlike phosphorus.
Participants express differing views on the reasons behind nitrogen's inability to form NCl5, with some focusing on atomic size and hybridization capabilities, while others emphasize the role of the octet rule and molecular geometry. The discussion remains unresolved with multiple competing explanations present.
Limitations include assumptions about atomic size, hybridization, and the definitions of non-conformist atoms, which may not be universally agreed upon. The discussion also reflects varying levels of understanding regarding molecular shapes and bond angles.
Raza
Chemistry Grade 12 Help|URGENT
Hi, I need some help with this question.
1)Phosphorus forms PCl3 and PCl5. Nitrogen forms NCl3 but not NCl5. Explain the reason why NCl5 doesn't form?
I know Phosphorus & Nitrogen are an exceptional to the octet rule but I don't know why NCl5 doesn't form.
2) If N, C and O all form sp3 hybrid orbitals, what reason can you give for NH3 and H2O being polar while CH4 is not.
I don't even know where to start. please help.
If you need me to rephase the question, please comment.
Also, a link to a site which could help me would be more than helpful.
1) think about the size of the phosphorus atom compared to that of nitrogen
2) draw the lewis structures first
This is what I wrote in my assignment:
1.Phosphorus forms PCl3 and PCl5. Nitrogen forms NCl3 but not NCl5. To tell you the reason why that is, I have to define what a non-conformist means. The definition a non-conformist is when an atom that does not follow the octet rule. Phosphorus and Nitrogen both are non-conformist. Phosphorus, however, is an atom that has more then 4 bonding and Nitrogen is an atom that contains an odd number of electrons. NCl5 would have 40 electrons which is an even number.
2.If nitrogen, oxygen and carbon all from sp3 hybrid orbitals, NH3 and H2O being polar while CH4 is not. The reason why ammonia and water are polar is because they have uneven distribution of electron density while methane is evenly distributed of electron density. CH4 have the same forces being pulled all four ways while NH3 and H20 don't.Water is polar because of the 2 lone pairs. Theoretically, if there was H40, it would be a non-polar. Again, if there was NH4, it would be non-polar too.
Is this correct?
The answer to (2) would rely on you explaining WHY H2O is a 'bent' shape and CH4 isnt.
I just edited the answer for question 2 on my previous post.
Another question that I am having trouble with:
What is the relation between the angles of clouds in a molecules and the orbital configuration?
I need the answer for this to answer this question:
The bond angles in CH4, NH3 and H2O are 109.50, 1070 and 104.50 respectively. How can these values be justified if sp3 hybrid orbitals are invloved in each case?
There is NH4, its called ammonium..
The bond angles of molecules depend solely on the combination of electron domains and molecular bonds. The E.D. tells you what the geometric shape of the bonds will be, then when you draw out your bonds and take off your empty electron domains youll get the molecular shape.
You haven't really said anything here except that they both violate the octect rule. NCl5 doesn't exist because nitrogen is too small to have 5 chlorine atoms "fit" around it.
Atoms which violate the octet rule such as phosphorus or sulfer are capable for sp^3d or sp^3d^2 hybridization accouting for the greater number of availible bonds. This doesn't occur with nitrogen because it doesn't have a d orbital to fill with electrons during hybridization. Hope that makes sense, but I'm sure you've already figured it out.
Yea, I figured it out. My friend told me that nitrogen doesn't have enough orbitals to get 5 ionic clouds like phosphorus.
  • · Replies 19 ·
11K
