Solving a Probability Problem with 4 Types of Objects: A, B, C, D
  • Thread starter Thread starter Jibobo
    Probability
The problem involves calculating the probability of drawing specific quantities of four types of objects (A, B, C, D) from a bag, where the probability of selecting each type is equal. The original poster expresses confusion about applying permutation and combination formulas to this scenario.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of the probability being constant at 1/4 for each type of object and question whether this allows for sampling with replacement. They explore how to calculate the probability of specific arrangements of the objects and the number of different orders possible.
Several participants have offered insights into the counting of arrangements and the application of factorials and combinations. There is an ongoing exploration of different methods to approach the problem, with some participants questioning their assumptions and others providing alternative ways to calculate the probabilities.
There is ambiguity regarding the interpretation of the problem's setup, particularly concerning whether the objects are replaced after being drawn. Participants are considering different scenarios and their implications for the calculations involved.
Jibobo
Or what seems like it. I can't seem to figure how to apply the premutation or combination formulas to the following problem and it's driving me mad:
"There are four types of objects: A, B, C, D. Enough are mixed together in a bag so that the probability of picking anyone of them out of the bag is always 1/4. If 9 total object are taken out, what's the probability of picking 4 A's, 2 B's, 2 C's and 1 D, in ANY ORDER?"
There isn't a clear-cut "success" or "failure" so I'm not sure what formula to write.
I'm going to assume that "Enough are mixed together in a bag so that the probability of picking anyone of them out of the bag is always 1/4" means that we can treat this as "sampling with replacement"- that is, taking an object of type A out does not (noticeably) affect the number of A objects in the bag.
What is the probability of getting AAAABBCCD in THAT order?
Do you see that you are alway multiplying (1/4)s together? Do you see that if I asked "what is the probability of getting "CCDBBAAAA" you would do exactly the same arithmetic and get the same answer? Do you see that that is true for any specific order?
Finally, how many different orders are there? How many different ways can you order the letters AAAABBCCD?
The question doesn't quite make sense to me. If there were only one of each type of object in the bag, then the chance of picking out anyone of them would be 1/4.
But the word 'always' implies that even if (say) a type-A object has already been taken out of the bag (and not put back in), then there is still a 1/4 chance of choosing a second type-A object. The only way this could happen is for there to be an infinite number of each object in the bag (and the same infinite number for each type).
To gloss over this ambiguity, assume that there is only one object of each type, but that it replaced back into the bag after each trial.
Now if you calculate the probablitity of only picking exactly one D, two Cs and two Bs in the nine trials you have your answer (if you pick those then you have to pick As on the remaining four trials, so you don't have to calculate that).
edit to add: Oops! I crossposted with HallsofIvy, who gave a more complete answer.
My main inability is in figuring out how to represent those many different orders as some sort of easy to calculate formula because the brute force method of just rearranging and counting would take forever.
I tried the brute force method to see if I could find something but nothing came to me.
If I start with AAAABBCCD and just move D around, there are 8 different combinations, and then the 1st C, there are another 6, 2nd C - 6, 1st B - 4, 2nd B - 4.
But then I have to assume what happens if I moved around 2 at once, and the numbers become way to large. If I assume my first move is AAAABBCDC, then the number of ways I can move the 1st C is 6, 2nd C - 6, 1st B - 5, 2nd B - 5.
I'm sure there's a pattern here...but I might be counting wrong as well.
Do you know permutation counting (factorials) and/or combination counting (binomial coefficients) ?
You can put the D in 9 places, the first C in 8 and the second C in 7.
9 x 8 x 7 = 504
But as you're not concerned which C is which then you'll get two equivalent arrangements every time (with the two Cs swapped) so you have to halve that.
504 / 2 = 252
Then you can put the first B in 6 places and the second in 5 places, and again you have to divide by 2 to stop double counting:
252 x 6 x 5 / 2 = 3780
You don't have to worry about the As - once you've counted all the possible arrangements for the Bs, Cs and Ds - the As just fill in the blank spaces and there is only one way of doing that for each arrangement.
There are a total of 9 letters: 4 A's, 2 B's, 2 C's, and 1 D.
Imagine first that you labeled them A1, A2, etc. so that all 9 were "distinguishable". Then there would be 9! ways of arranging them.
But some of those are identical except for the labels. That is, one might be
A1A3B1C1B2DA4CA2 while another might be A3A1B1C1B2DA4CA2- identical except that the first two A's have been switched. How many ways are there of just switching the A's around? 4! of course. Since we don't want to count those as different, we need to divide by 4!. Similarly, there are 2! ways to swap the B's and 2! ways to swap the C's. Since we don't want to count those as different, there are [itex]\frac{9!}{4!2!2!}[/itex] ways of ordering AAAABBCCD.
Since the probability of anyone ordering is (1/4)9, the probability of getting 4 A's, 2 B's, 2 C's, and 1 D is
[tex]\frac{9!}{4!2!2! 4^9}[/tex].
Another way of getting the same answer is to ask the probability of choosing an exact sequence, in order. As there are 9 choices each with a 1 in 4 probability this is 1/4 x 1/4 x 1/4 (nine times) = 1 / 4^9 = 1 / 262144
and we already worked out that there are 3780 ways of arranging one D, 2 Cs, 2 Bs and 4 As so the answer is
[tex]\frac{3780}{262144} = \frac{945}{65536} = \frac{3^3 \times 5 \times 7}{2^{16}}[/tex]
Wow, thanks. I must've been approaching the problem totally wrong. I kept trying to figure out how to use N!/(r!*(N-r)!) but I should've been thinking about 4 outputs (A, B, C, D), not just two (Success, Failure) to get:
N!/[(N-b-c-d)! * (N-a-c-d)! * (N-a-b-d)! * (N-a-b-c)!] =
9!/[(9-2-2-1)! * (9-4-2-1)! * (9-4-2-1)! * (9-4-2-2)!] =
9!/(4! 2! 2!)
Thanks a lot. I just couldn't see it.
Also, I didn't really understand how to think of the denominator in N!/(r!(N-r)!) until you explained it.
