Velocity in two motions (X and Y) ?
  • Thread starter Thread starter vinny380
    Velocity
The problem involves calculating the necessary heading and airspeed for a plane to reach an airport 450 km due south while accounting for a wind blowing from the west at 50 km/h. The context includes the use of vector addition to determine the resultant velocity needed to achieve the destination within a specified time frame.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between displacement, time, and velocity, with one participant calculating average velocity based on distance and time. There is confusion about mixing units of velocity and displacement, and questions arise about the role of the wind in determining the required heading and airspeed.
Participants are actively engaging with the problem, with some providing guidance on using Pythagorean theorem and trigonometry to find the necessary values. There is recognition of the need to clarify the relationship between average velocity and the effects of wind, but no consensus has been reached on the final approach.
There is a noted concern about mixing units in the calculations, and participants are exploring the implications of the wind's velocity on the overall flight path. The inclusion of time in the problem is also questioned, as it seems to have been overlooked in initial calculations.
vinny380
Velocity in two motions (X and Y) ??!
Just wondering if anyone could guide me on this question:
1) You are piloting a small plane, and you want to reach an airport 450 kn due south in 3.0 hours. A wind is blowing from the west at 50.0 km/h. What heading and airspeed should you choose to reach your destination?
First, I drew a triangle on the cordinate gird (X and Y axis). I made one of the legs 50.0 km/h, and the other 450 km.
Ax + Bx = Rx
So Rx = 50.0
Ry = 450
R^2= Rx^2 + Ry^2
R^2= 50^2 + 450^2
R= 452.8 km/h
Is this the correct answer? I really don't know because why then would they include a time (3 hrs.) which I didnt even need or use. I am really stuck on this trouble. Also, am I just trying to find velocity? Whats heading?
Thanks!
BTW - my teacher said this was a pretty easy problem, so it should not be too difficult...
The first problem is that you're mixing units. One leg of your triangle is a velocity and another is a displacement. You can't do that.
Think about the problem for a moment. You know the displacement you want and you know the time - that will give you the average velocity. If you assume that your velocity remains constant, then the average velocity will be the same as the instantaneous velocity. This is where the triangle comes in - at what course and speed do you have to fly so that your airspeed velocity (and I suddenly feel like I'm in a Monty Python movie) vector-summed with the wind's velocity will give you the velocity you want.
Does that help?
I understood the first part - but I am still a little confused ...
So V= D/T
V= 450/3
V= 150 km/h <----- Average velocity
What do I do next?
Now you have a velocity (150kmh-1) due south and a wind of 50 kmh-1 from the west (pointing east). You can use Pythagoras' Theorem to calulate a value for V (assuming that you want to reach you destination in 3 hours)!
Technically you can travel faster than V if you wanted, you'd just get there sooner a different direction would have to be flown.
And the direction of velocity can be calculated with trigonometry.
If you would like a graphical representation, I'd be glad to help.
Regards,
Sam
  • · Replies 16 ·
  • · Replies 46 ·
