Find Magnitude of Initial Acceleration for Rod of Length 1.29m
The discussion focuses on calculating the initial acceleration of a uniform rod of length 1.29 m, pivoted at one end and released from an angle of 21.0° above the horizontal. The moment of inertia (I) was initially calculated using the formula I = (1/2)ML^2, yielding I = 0.832 kg*m². However, the correct moment of inertia for a uniform rod is I = (1/3)ML². The torque (τ) was computed as τ = 2.27 Nm, leading to an angular acceleration (α) of 2.73 rad/s², and a linear acceleration (a) of 1.76 m/s². The discussion emphasizes the importance of using the correct inertia formula and understanding the angle for torque calculations.
  • Understanding of rotational dynamics and torque
  • Familiarity with moment of inertia concepts
  • Knowledge of angular acceleration and its relation to linear acceleration
  • Basic trigonometry, specifically sine functions
  • Study the moment of inertia for different shapes, focusing on uniform rods and disks
  • Learn about the right-hand rule for torque and angular motion
  • Explore the relationship between angular and linear acceleration in rotational systems
  • Review the principles of dynamics related to pivoted objects and their motion
Students and educators in physics, mechanical engineers, and anyone involved in understanding rotational motion and dynamics of rigid bodies.
Punchlinegirl
A uniform rod of length 1.29 m is attached to a frictionless pivot at one end. It is released from rest from an angle q = 21.0° above the horizontal. Find the magnitude of the initial acceleration of the rod's center of mass.
[tex]I= (1/2)ML^2[/tex]
I= (1/2)(1.29^2), since mass isn't given I just used 1 kg.
I=.832 kg*m^2
[tex]\tau= rFsin \theta[/tex] =.645(9.8)(sin 21)= 2.27 Nm
[tex]\tau = I \alpha[/tex]
2.27= .832 [tex]\alpha[/tex]
[tex]\alpha[/tex] = 2.73 rad/s^2
[tex]a= \alpha * r[/tex]
a= 2.73 * .645
a= 1.76 m/s^2
This isn't right.. can someone help me?
This is not a uniform DISK, it is a uniform ROD.
Look up in a table the Inertia
(unless you want to calculate it yourself, using integration)
is it 1/3 M L^2 , or is it 1/12 M L^2 ?
Also, the angle theta that you take the sine of
is the angle that sweeps from the r_vector direction
to the F_vector direction ... as in the right-hand-rule?
(gravity is down, not sideways! )
I got it. Thanks
  • · Replies 17 ·
