Visual Basics programming help required
The discussion revolves around a Visual Basic programming assignment that requires creating a program to simulate particles moving within a bounded Cartesian coordinate system. The original poster seeks assistance with generating random initial positions for multiple particles and ensuring they reflect off the boundaries of the defined area.
  • Exploratory, Problem interpretation, Assumption checking
  • The original poster attempts to implement a basic program for a single particle and is exploring how to generate random initial coordinates for multiple particles. Participants suggest using the Randomize() function to initialize the random number generator and discuss how to store and update the positions and velocities of multiple particles.
Participants have provided guidance on using the Randomize() function and generating multiple particles. The original poster has made progress in implementing suggestions but is still encountering issues with the array setup and is seeking further clarification on how to properly initialize and update particle positions and velocities.
The original poster mentions a lack of literature or reference materials, which may be impacting their understanding of certain functions and concepts in Visual Basic. There is also a focus on ensuring that the program adheres to the assignment requirements while addressing specific coding challenges.
zanazzi78
I've posted this in the homework section since it is an assinment.
I am required to write a program in VB than creats N number of 'particles' in a random position within a caresian co-ordinate system. The x and y-axis are to go from -100 to 100 and be bounded i.e if a particle's x or y component reach 100 or -100 then it`s angle of incidence must equal it angle of reflection.
Now I`ve started off by writing a simplified program for a single particle that just bounces around in it's 'box' here's the code so you can see what i`ve done.
Code:
Option Explicit
Dim x, y, speed_x, speed_y As Double
Dim i, j, delta_t, t As Long
Private Sub Command1_Click()
'defines the dimentions of the box
Picture1.Scale (-100, 100)-(100, -100)
'declare variables
speed_x = Rnd * 10
speed_y = Rnd * 10
delta_t = 1
'make the circle move
For t = 1 To 200 Step delta_t
x = x + speed_x
y = y + speed_y
If x > 95 Or x < -95 Then speed_x = -speed_x
If y > 95 Or y < -95 Then speed_y = -speed_y
Call plot(x, y)
Call Delay(t)
Picture1.Cls
Next t
End Sub
'create a purple circle in a subroutine called plot (x,y)
Sub plot(x, y)
Picture1.FillStyle = 0
Picture1.FillColor = RGB(255, 0, 255)
Picture1.Circle (x, y), 5, RGB(255, 0, 255)
End Sub
'pause circle with a subroutine called delay (t)
Sub Delay(t)
For i = 1 To 1000000
Next i
End Sub
The first problem i have is i can`t randdomly generate the inital (x, y) co-ordinates, remebersinf the Rnd command creates a positive number between 0 and 1. Scaling this isn`t a problem, but getting it to appear anywhere other than (x, y) for X>0 and y>0, is causing me a head ache.
Once i can work than out i don`t know how to generate more than one circle in a picture box?
PLEASE, PLEASE HELP :cry:
Don't you have to call Randomize() before you generate a random number?
I don`t know. I`ve told about the Rnd command but nothing else and unfortunately i don`t have any litreture to refer to.
Could you explain the Randomize() function please.
Edit: Ignore the aboce. I`ve just tried the Randomize () command with the Rnd Command and it seems to work but how do i randomize my inital (x,y) co-ordinated and then keep them?
DO i simple say
Randomize (x,y)
x= Rnd*10
y= Rnd*10
and add this before the fr loop?
Yes, you have to call Randomize() first, because it initiates the random generator.
Option Explicit
Randomize Timer
'declare variables
speed_x = Rnd * 10
speed_y = Rnd * 10
delta_t = 1
x = (Rnd * 200) - 100
y = (Rnd * 200) - 100
x = x + speed_x
y = y + speed_y
Call plot(x, y)
Call Delay(t)
Picture1.Cls
Next t
End Sub
Sub plot(x, y)
DoEvents
End Sub
Sub Delay(t)
Next i
End Sub
Thank you all very much.
The randomize timer starts the generation process. and then every time you use Rnd you get a new number, now i get it.
Could i ask one more question?
How do you generate more than one circle?
Code:
Option Explicit
Dim x(10), y(10), speed_x(10), speed_y(10) As Double
Dim p, i, j, delta_t, t As Long
Dim NumPart As Long
NumPart = 5
Randomize Timer
'declare variables
For p = 1 To NumPart
speed_x(p) = Rnd * 10
speed_y(p) = Rnd * 10
delta_t = 1
x(p) = (Rnd * 200) - 100
y(p) = (Rnd * 200) - 100
Next p
x(p) = x(p) + speed_x(p)
y(p) = y(p) + speed_y(p)
If x(p) > 95 Or x(p) < -95 Then speed_x(p) = -speed_x(p)
If y(p) > 95 Or y(p) < -95 Then speed_y(p) = -speed_y(p)
Call plot(x(p), y(p))
Next p
Call Delay(t)
Picture1.Cls
Next t
End Sub
Sub plot(x, y)
DoEvents
End Sub
Sub Delay(t)
Next i
End Sub
Set the NumPart variable the number of particles..
Burnsys thanks again but implimenting your changes doesn`t seem to work!
I can see what you've tried to do, creating a function p of x,y but i think i need to creat an array to hold the initial position vectors and then use this array to 'update' the movement of the ball and a second array to hold the velocities of the particles.
My problem now is that vb wants my array, eg. Mat_A(i, j), to equall something and i`m at aloss as to what it should equal, any hints?
right, i tested it and it works fine, just paste the entire code and it should work-
The initial position vector is set here:
The velocity vector is set here:
And here is the movements of the balls:
What is the literal error in vb? what is the error description? and in what line?
Try pasting the code in a new proyect. it should work
17K
  • · Replies 21 ·
9K
