Calculating Light Energy and Consumption: A 60W Bulb Left On for 10 Hours
  • Thread starter Thread starter RMHAZARD
The problem involves calculating the light energy produced by a 60 watt light bulb that is left on for 10 hours, considering its efficiency of 15%. Participants are tasked with determining both the light energy output and the total energy consumption.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between power, time, and energy, with some questioning the need to introduce the concept of work. There are attempts to clarify the correct units and calculations needed to find the energy output and consumption.
The discussion is ongoing, with participants exploring different interpretations of the calculations. Some guidance has been offered regarding unit conversions and the relationship between watts and time, but no consensus has been reached on the correct approach.
Participants are navigating the challenge of converting time from hours to seconds, and there is a focus on ensuring that calculations align with the correct units of measurement.
RMHAZARD
hi here is the question
A 60 watt light bulb is left swithed on for 10 hours. If the light bulb is 15% effcient, calculate the amount of light energy produced in that time. what is the total energy consumption of the light bulb in this time.
so i need to find work done right so is that power divided by time to get the energy and then find 15% of that am i right i am bathed by this.
A watt is 1 unit of energy per unit time. You know how much of the energy was turned into light (15%) and the length of time the light was left on. No need to introduce work.
so do i divide watts by time taken?
so 60 watts divided by10 hours which is 6 15% of 6 is 0.9 if i am correct
can you please tell me if i am right if not can you advive me where i went wrong
your answer is incorrect. First you need to think about units
watts is per second whereas you're given a time in hours. Secondly do you think the energy would be lower or higher than how much you are using in one second?
so 10 hours is 600 minutes 36000 seconds and 60 watts goes goes in in 36000 2160000 so 15% 324000 am i right
Correct. now remember to state you units. energy is measured in...
