Functions of Continuous random variables
The discussion centers on the calculation of probabilities involving continuous random variables, specifically addressing the probability density function (PDF) of a variable X defined as f(x) = 1/4 for -2 ≤ x ≤ 2. The problem involves finding P(Y ≤ 1/2) where Y = 1/X. The initial approach incorrectly concluded that P(X ≥ 2) equals 1, while the correct answer is P(Y ≤ 1/2) = 1/2. The error was identified in the treatment of the variable X, which can take both positive and negative values within the specified range.
  • Understanding of continuous random variables
  • Knowledge of probability density functions (PDFs)
  • Familiarity with algebraic manipulation of inequalities
  • Basic concepts of integration in probability
  • Study the properties of continuous random variables
  • Learn about probability density functions and their applications
  • Explore the method of transforming random variables
  • Investigate the use of integrals in calculating probabilities
Students and professionals in statistics, mathematicians, and anyone involved in probability theory and its applications in real-world scenarios.
Disar
I have been working on this problem and can't seem to get the answer.
Problem:
X is a continuous random variable with a proabaility density function:
f(x) = 1/4 if -2<=x<=2
0 other wise
Let Y=1/X. Then P(Y<=1/2) = ?
This is how I approached the problem:
P(Y<=1/2)=P(1/x=1/2)
=P(X>=2)
Taking the intergral of f(x) with limits of integration -2,2.
My answer is 1.
However the answer given is 1/2.
Any ideas.
Reply
Hmm.. Since it is given in the question that x runs from -2 to 2 only, how can [tex]P(X\geq2)[/tex] be 1? Shouldn't it be 0?
Well, your working [tex]P(Y\leq \frac{1}{2}) = P(\frac{1}{X}\leq \frac{1}{2})[/tex] is correct. The error lies in your subsequent statement "which is in turn equal to [tex]P(X\geq2)[/tex]"
You see, since x runs from -2 to 2, it can take both positive and negative values. So, should we treat x as positive or negative, knowing that the subsequent working will be affected by our decision? (i.e. If x is negative, then we will need to change the inequality sign when cross-multiplying)
To solve this problem, we multiply the inequality by [tex]x^2[/tex], since we know for sure that this expression is positive (x cannot be equal to zero if y is to be real)
The resulting inequality will be quadratic in nature, and some algebraic manipulation should get you the desired probability of 0.5.
All the best!
  • · Replies 40 ·
