Help with vectors and 2-dimentisonal motion: relative velocity
The problem involves a science student on a train throwing a ball at an angle, with observations made by a professor on the ground. The context is centered around vectors and two-dimensional motion, specifically relative velocity.
  • Participants discuss the application of Galilean transformation to relate the velocities in different frames of reference. Questions arise regarding the calculation of the ball's velocity from both the moving train and the stationary ground perspective.
The discussion is ongoing, with some participants providing insights into the principles of relative motion and velocity transformations. There is no explicit consensus yet, as various interpretations and calculations are being explored.
Participants are navigating the complexities of relative motion and the effects of different frames of reference, with some details about the problem setup still under consideration.
xkamranx
A science student is riding on a flatcar of a train traveling along a straight horizontal track at a constant speed of 10 m/s. The student throws a ball along a path that he judges to make an initial angle of 60° with the horizontal and to be in line with the track. The student’s professor, who is standing on the ground nearby, observes the ball to rise vertically. How high does the ball rise?
Thanks a lot.
anyone haev any idea?
The basic principle for this problem would be to use the Galilean transformation for inertial frames. In simpler words, if you know the velocity of an object in a moving frame, what is the velocity of that same object in a stationary frame?
Once you know this, you can use it's inverse into your problem. Knowing the apparent velocity in the stationary frame, what is the velocity in the moving frame?
The train is moving with a speed of 10 m/s . The balls horizontal velocity is
[tex]v\sin{60}[/tex]. From the ground, the horizontal velocity is zero. Can you calculate the magnitude of the balls velocty from this?
  • · Replies 38 ·
  • · Replies 30 ·
  • · Replies 18 ·
