Will All the Ice Melt in a Box with a Heat Capacity of 80J/K?
  • Thread starter Thread starter Izekid
The discussion revolves around the thermal dynamics of a system containing a box with a heat capacity of 80 J/K, 0.2 kg of water at 18°C, and 0.05 kg of ice at -15°C. The calculations indicate that the total energy available from the water and box is insufficient to raise the ice's temperature to 0°C and subsequently melt it. Specifically, the energy released by the water cooling from 18°C to 0°C does not meet the energy requirement to melt the ice, confirming that not all the ice will melt.
  • Understanding of heat transfer principles
  • Knowledge of specific heat capacity calculations
  • Familiarity with phase change concepts, particularly melting
  • Basic thermodynamics, including energy conservation
  • Study the concept of latent heat of fusion for ice
  • Learn about energy conservation in closed systems
  • Explore specific heat capacity values for various substances
  • Investigate the effects of temperature changes on phase transitions
Students in physics or engineering, educators teaching thermodynamics, and anyone interested in understanding heat transfer and phase changes in thermal systems.
Izekid
Here's my problem
A box with the heathcapacity 80J/K contains 0,2kg water. The box and the water has together the temperatur 18*C. We put 0,050kg ice with the temperature -15*C in the box of water. Investigate if all ice melts. Don't take with heath from the surrondings.
Well for this problem I though like this
0,2Kg Water * 4,19(water's heath capacity) = 0,838 + 80J/K =0,8380008
Then I took the Ice capacity = 0,050kg * 4,19 = 0,2095
0,8380008-0,2095 =0,62858
Then let's do it to Kelvin 273+18=291K
273-15=258K
0,62858 * -33 K = -20,7314
But that doesn't say me nothing if the Ice has melted?
How do I know that?
Think this way: How much energy is required to melt the ice? You must first raise the temperature from -15 to 0, then melt it.
Now ask: Does the box + water have enough energy to melt that ice? How much energy will the box + water release if it cooled from 18 degrees to 0?
  • · Replies 17 ·
