How Far Will the Spring Compress When Dropping a 5.8 kg Block?
The discussion centers on calculating the compression of a vertical spring when a 5.8 kg block is dropped onto it. The spring constant is given as k = 495 N/m. The correct approach involves using the formula for spring compression, where the force exerted by the block (weight) equals the spring force at maximum compression. The correct compression distance is determined to be approximately 0.1148 meters, but the initial calculation was incorrectly derived due to misunderstanding the relationship between force and distance.
  • Understanding of Hooke's Law and spring constants
  • Basic knowledge of gravitational force calculations
  • Familiarity with Newton's second law of motion
  • Ability to manipulate algebraic equations
  • Review Hooke's Law and its applications in mechanics
  • Study gravitational force calculations for different masses
  • Learn about energy conservation in spring systems
  • Explore dynamic systems involving springs and oscillations
This discussion is beneficial for physics students, mechanical engineers, and anyone interested in understanding the dynamics of spring systems and force interactions.
DStan27
A vertical spring with k = 495 N/m is standing on the ground. You are holding a 5.8 kg block just above the spring, not quite touching it.
How far does the spring compress if you let go of the block suddenly?
i thought i could just use k = F/distance
so 495(D) = (5.8)(9.8)
D = .1148 but this is not correct. i take it i am doing something wrong with my acceleration but I'm not sure what. can anyone help me with this?
nevermind i figured it out.
