What are the key steps for solving a tennis ball impulse problem?
The problem involves calculating the impulse experienced by a tennis ball of mass 0.060 kg and speed 25 m/s as it strikes a wall at a 45-degree angle and rebounds at the same speed. The discussion centers around the application of the impulse-momentum theorem and the need to analyze velocity components.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the necessity of breaking down the velocity into its components and question how the rebound affects the vertical component of the velocity. There is mention of using the impulse-momentum theorem as part of the approach.
Some guidance has been provided regarding the breakdown of velocity components and the application of the impulse-momentum theorem. Participants are exploring the implications of assumptions, such as the absence of friction, but no consensus has been reached on the complete approach to the problem.
One participant expresses a desire to include a diagram for clarity, indicating a potential constraint in visualizing the problem setup.
jacy
hi,
I am trying to solve this problem.
A tennis ball of mass m=0.060kg and speed v= 25m/s strikes a wall at a 45 degree angle and rebounds with the same speed at 45 degree. What is the impulse given to the ball?
Do i need to break velocity into its components. Please suggest me a hint, thanks.
Yes you do need to break velocity into components. If there is no friction (a sensible assuption in this case), would the rebound affect the vertical component of the velocity?
Hope this helps,
Sam
Once you break it into components use the impulse-momentum theorem:
[tex]\int\mathbf{F}\,dt=m\mathbf{v}_f-m\mathbf{v}_i[/tex]
impulse
Hope this helps,
Sam
Thanks for replying. I wish i could draw the diagram. Is there a way that i can insert the diagram. Plz let me know
  • · Replies 19 ·
18K
  • · Replies 24 ·
