How long does it take to reach the singularity in a free fall at r=0?
  • Context: Graduate
  • Thread starter Thread starter LAHLH
    Singularity Time
The discussion revolves around the proper time it takes for an object in free fall to reach the singularity at r=0, starting from outside the event horizon (r>2m). Participants explore the mathematical framework involving timelike radial geodesics, Killing vectors, and the implications of variable mass in the context of black hole physics.
  • One participant proposes using the Killing vector to derive the proper time to the singularity, suggesting the use of the equation E=-K_{\mu}\tfrac{dx^{\mu}}{d\tau} and integrating to find total proper time.
  • Another participant questions the application of the momentum vector along the Killing vector, noting that mass is not constant for an object falling into a black hole and suggesting corrections for variable mass.
  • A participant references a source (Carroll) that discusses energy per unit mass, indicating a potential resolution to the mass constancy issue.
  • There is a discussion about the affine parameter lambda and its role in the geodesic equations, with some confusion about the legitimacy of certain derivations presented in the literature.
  • One participant mentions using R for Eddington-Finkelstein coordinates and discusses the properties of these coordinates compared to Schwarzschild coordinates.
  • A later post provides a specific formula for the proper time to fall to the origin from a given Schwarzschild distance, referencing external literature for derivation.
Participants express differing views on the application of the Killing vector and the treatment of mass in the equations. There is no consensus on the correct approach to derive the proper time to the singularity, indicating multiple competing views remain.
Participants note limitations regarding the assumptions of constant mass and the applicability of certain equations in different coordinate systems. The discussion reflects ongoing uncertainties in the mathematical treatment of free fall into a black hole.
LAHLH
Let's say you start outside the event horizon r>2m, how long does it take according to your own wristwatch to hit the singularity at r=0 (ignoring the fact the tidal forces rip you apart...), assuming you just free fall and plunge in radially?
I'm thinking you need to consider the timelike radial geodesics since you are in free fall. These can be simplified by noting that [tex]K^{\mu}=(1,0,0,0)[/tex] is a Killing Vector, so we have a constant of motion [tex]E=-K_{\mu}\tfrac{dx^{\mu}}{d\tau} =(1-\tfrac{2M}{r})\tfrac{dt}{d\tau}[/tex], then expanding [tex]g_{\mu\nu}U^{\mu}U^{\nu}=-1[/tex] and using the energy constant. I get: [tex]\left(\frac{dr}{d\tau}\right)^2=E^2-1+\tfrac{2m}{r}[/tex]
Can I now just invert this to get [tex]\tfrac{d\tau}{dr}[/tex] and integrating from the starting value of r to r=0? and get total proper time? [tex]\Delta\tau=\int^{0}_{R} \frac{d\tau}{dr}dr[/tex]
(I calculate the above in ingoing Eddington Finkelstein coords [tex]ds^2=-(1-\frac{2m}{r})dv^2+2dvdr+angles[/tex])
You do need to use the Killing Vector for this, that's correct, but I'm not sure where you are getting this.
[tex]E = -K_{\mu}\frac{dx^{\mu}}{d\tau}[/tex]
The momentum vector along Killing Vector, Kμpμ, should be conserved. What you have up there is a proper velocity, and pμ=muμ. The problem here is that m is not constant for object falling into a black hole. You can easily verify that by using the above constraint with the fact that uμuμ=c².
Take correction for variable m, and you should have it.
thanks for the reply. hmm, I got the equation from Carroll chapter 5 (5.61). I believe he also states that E is energy per unit mass, so maybe that fixes things. In general he seems to use
[tex]K_{\mu}\frac{dx^{\mu}}{d\lambda}=constant[/tex] however e.g. (5.54)...(text is free online if you don't have a copy). Although the derivation in chp3 does seem to indicate it's for p not u.
What's lambda?
The equation you stated is valid for constant mass, except the constant isn't going to be energy. It's going to be energy per unit of mass. It would be sufficient to find time to event horizon, but mass is not constant, and that's the whole point.
Use Kμpμ = const, and uμuμ=c². You should be able to derive it from just these two things and the metric.
K^2 said:
What's lambda?
Well lambda is the affine parameter parametrising the geodesic. If we call the tangent vector to the geodesic [tex]u^a[/tex] and consider [tex]\tfrac{d}{d\lambda} (K_a u^a)=u^c \nabla_c (K_a u^a)=u^a u^c \nabla_c K_a+K_a u^c \nabla_c u^a[/tex].
The second term here is zero by the geodesic equation (usually anyway in my proof perhaps this is where things are different in this case). Then the uu is symmetric so picks out the symmetric part in first term:
[tex]=u^a u^c \nabla_{(c} K_{a)} =0[/tex] if K is a KV.So anyway, I suspect you're going to say this proof falls because of the [tex]u^c \nabla_c u^a=0[/tex] by the geodesic equation part? because it should be [tex]p^c \nabla_c p^a =0[/tex] if m is not a constant along the motion. I can't argue with this, but am somewhat confused at why my notes and Carrol use the above. How is Carroll legitimate in using the form in my original post? Also the fact that [tex]\epsilon=-g_{\mu\nu}\frac{dx^{\mu}}{d\lambda}\frac{dx^{\nu}}{d\lambda}[/tex] is constant along the path seems to rely on a similar proof that doesn't quite work.
EDIT: isn't the m in [tex]p^a=m_0 u^a[/tex] actually the rest mass? so is a constant and everything works except the energy E I had is just the energy per unit mass (which Carroll states later on in the chapter.) [tex]0=p^c \nabla_c p^a =m_0 u^c \nabla_c (m_0 u^a)[/tex] which implies [tex]u^c \nabla_c u^a=0[/tex]
I often use [itex]R[/itex] for Eddington-Finkelstein coordinates instead of the more usual [itex]r[/itex]. Even though [itex]R = r[/itex] is one of the coordinate transformation equations from Schwarzschild to Eddington-Finkelstein, [itex]\partial / \partial R \ne \partial / \partial r[/itex], and, unlike [itex]r[/itex], [itex]R[/itex] is everywhere a lightlike coordinate! Also, [itex]v[/itex] has the same causal properties as [itex]t[/itex], since [itex]\partial / \partial v = \partial / \partial t[/itex], even though [itex]v \ne t[/itex]!
Since [itex]\partial / \partial v = \partial / \partial t[/itex], this coordinate expression gives the same Killing vector in both coordinat systems.
But in the Eddington-Finkelstein coordinate system that you have used, there is no "[itex]t[/itex]". What is (the same) [itex]E[/itex] in the Eddington-Finkelstein coordinate system?
Yes. The constant [itex]E[/itex] is determined by initial conditions. A typical iinitial condition is that the observer is initially at rest with respect to a hovering observer.
For a particle released from rest at a Schwarzschild distance r=R from the origin, the proper time to fall to the origin r=0 is (pi R/2)sqrt(R/2m). You can find the derivation in any good book on relativity. See for example http://www.mathpages.com/rr/s6-04/6-04.htm
  • · Replies 0 ·
