Negative Mass: Possibility of FTL Travel?
The discussion revolves around the concept of negative mass and its implications for faster-than-light (FTL) travel. Participants explore various theories and models that suggest the possibility of negative mass, its relationship with superluminal velocities, and the theoretical frameworks that might support such ideas.
  • Some participants propose that negative mass could allow for FTL travel, suggesting that mass must be a pure imaginary number rather than simply negative.
  • Others reference Fred Hoyle's mass field theory, which posits that mass can vary and may become negative, affecting the behavior of photons in the universe.
  • There are discussions about cosmological models involving phantom energy, which may violate energy conditions and imply FTL effects, though some participants express uncertainty about the implications of these models.
  • Some participants argue that imaginary mass or energy is required for FTL velocities, but note that such concepts may lack physical meaning.
  • There is mention of vacuum domain walls with negative gravitational mass density, suggesting that objects made of normal matter would be repelled by such structures.
  • Participants clarify that while negative mass is a theoretical prediction, it has not been demonstrated experimentally, and the requirements for negative mass remain uncertain.
  • Some contributions discuss the historical context of general relativity and the cosmological constant, linking it to the concept of negative mass or anti-gravity.
Participants express a range of views on the existence and implications of negative mass, with no consensus reached on its validity or the conditions under which it might occur. The discussion remains unresolved regarding the physical reality of negative mass and its potential for FTL travel.
Limitations include the speculative nature of the theories discussed, the dependence on mathematical constructs that may not have real-world applications, and the lack of empirical evidence supporting the existence of negative mass.
eNathan
Is there any theories or something of that sort, which allows negative mass? Hence, v > c rather than v < c. This seems like the only logical possibility to FTL travel.
It's not m < 0 that allows v > 0; because the energy dilation formula is a function of [tex]\frac {1}{\sqrt {1 -\frac{v^2}{c^2}}}[/tex], the requirement is m^2 < 0. This means that mass has to be a pure imaginary number, a multiple of [tex]i = \sqrt{-1}[/tex].
It has nothing to do with superluminal velocities, but Fred Hoyle postulated a mass field theory, a version of his conformal gravity approach, where the value of m varied from event to event. The mass field went negative beyond a zero mass field surface. ("On the Origin of the Microwave Background", Ap.J. 196:661-670 1975 March 15) He postulated that as photons went from a -mass field to a +mass field region they were thermalised and became the microwave background, which is simply the light from galaxies beyond that zero-mass field surface.
Garth
In the cosmological models which postulate a phantom energy (a fluid with [itex]p < - \rho[/itex]) leading to a big-rip, the dominant energy condition in general relativity is violated. As far as I know this implies FTL effects.
I don't know if it IMPLIES FTL effects, I believe it is true that FTL effects break the weak energy condition. FTL => ~WE does not prove DE => FTL.
My understanding is consistent with SA's explanation. Imaginary, not negative mass is required for FTL velocities. But those are unphysical results. You can play other mathematical games and come up with concepts like negative or imaginary gravity, or light speed, with similar results. Just because a mathematical solution exists doesn't mean it has any real world meaning.
One can prove that a violation of the dominant energy condition implies that the energy flow can be superluminal. But may be this is not the same as matter being superluminal (e.g. a sound wave could be superluminal), isn't it?
Note is that any superluminal effect (which could transmit information!) could be described by this equation: E = mc2/(1-v2/c2)1/2
If v>c, then either the energy is imaginary (for real mass) or the mass is imaginary (for real energy). (imaginary, mathematically, meaning you have taken the square root of a negative number). So we will have to figure out what imaginary mass or energy is.
it is imaginary, meaning it has no physical meaning.
I think this is not always the case, but I am not sure of that and this is actually what I was trying to say in my previous posts: in general relativity one can have superluminal propagation of (at least) energy flows with real positive energy densities, but with a negative pressure such that [itex]p/c^2 < - \rho[/tex]. The arguments I have seen in some references are as follows: either,<br /> <br /> (a) you take [itex]dp/d\rho > c^2[/itex] to be the (squared) speed of sound of a sound wave, or, <br /> <br /> (b) you consider [itex]T^{\mu}_{\nu} U^{\nu}[/itex] to be a energy flow, which is spacelike if the dominant energy condition is violated ([itex]U^{\nu}[/itex] was timelike).<br /> <br /> (OTOH it can be easily proven that the condition [itex]p/c^2 < - \rho[/tex], implies a violation of the dominant energy condition).[/itex][/itex]
Yes. As for an example, look at what is know as a "vacuum domain wall". Its active gravitational mass density is negative (due to negative pressure). An object made of normal matter will be gravitationaly accelerated away from the wall.
Pete
Pete
Are you saying that negative mass, or "negative gravity" has already been demonstrated? What are the exact physical requirements for negative mass?
None of this stuff has been demonstrated. It's all theory - various different theories.
Its a prediction made using general relativity.
Pmb
Reply to question abaout negative mass
Hi.
You might like to take a look at the webv site:
www.negative-mass.com
Ed Miksch
Hi.
Ed Miksch
How does GR theory predict that? :confused:
Or do you consider mathematically possible equivalent to prediction?
Yes. Einstein used to assume that the universe was static. But in order to have a static universe there must be a repulsive component to gravity on a cosmological scale. For this reason he introduced the cosmological constant. Later when evidence came in that the universe was not static but expanding he said of his mistake "That was the biggest blunder of my life!" But he spoke to soon! Recently observations of the universe have indicated that not only is the universe exanding, but it is doing so at an accelerating rate!
The only thing that can cause this acceleration is either a positive cosmological constant or a large negative pressure. I don't think they know which yet. In any case this repulsive source of gravity can be referred to as negative mass or anti-gravity.
See - http://www.iop.org/EJ/abstract/1742-6596/8/1/016
Best wishes
Pete
Best wishes
Pete
Sorry but I do not see how you could call that a prediction of GR.
Within the theory of GR there is no logic to the addition of such a constant it simply a hack to match the experimental data.
Until we can demonstrate that there is something like negative mass we should question GR like any other scientific theory.
Otherwise we might as well make an axiom that GR is eternally true and if we find that some experimental data do not match it must be caused by invisible pink unicorns. :smile:
Okay. How would you phrase it?
And you believe that the universe is accelerating at an acccelerating ratre because...?
This acceleration is not unique to the current expansion. This negative pressure/mass is what drove inflation
That's just nuts! unicorns are white! :biggrin:
Pete
:smile:
It could be some dark matter or it could be that GR is not quite as exact as some wish to believe it is. :smile:
Point is, we don't know for sure until we can demonstrate the existense of dark matter.
And demonstrate to me does not mean to a priori assume GR is correct and then pointing to some experimental data that disagrees with the theory and thus, QED, concluding that there must be dark matter. :smile:
Isn't negative pressure different from negative energy? Maybe negative energy would also tend to have negative pressure, but I didn't think that negative pressure would necessarily imply the presence of negative energy. http://www.physics.hku.hk/~tboyce/sf/topics/wormhole/wormhole.html (written by two physicists who have 'collaborated on negative energy issues for over a decade' according to their bio at the bottom) says:
One should also not confuse negative energy with the energy associated with the cosmological constant, postulated in inflationary models of the universe [see "Cosmological Antigravity, by Lawrence M. Krauss; SCIENTIFIC AMERICAN, January 1999]. Such a constant represents negative pressure but positive energy. (Some authors call this exotic matter; we reserve the term for negative energy densities.)
The active gravitational mass density is a function of the energy density as well as pressure. The pressure could be negative to the extent that the active gravitational mass would be negative.
Note: Einstein's equations were constructed so as to describe nature. When Einstein added a cosmological constant all he was doing was what he had been doing - Creating equations which described nature. The equations are now in the most general form they can be with this constant. I don't see this as an ad hoc way of constructing them.
Best wishes
Pete
That's alrady been done. WE can observer the presence of dark matter by observing the gravitational effects it has on galaxies
What is it you believe would constitute evidence of the existence of dark matter?
Best wishes
Pete
So, it's not possible at all, in GR, to explain those galactic effects , without assuming the existence of dark matter?
That is correct.
So either the theory is incomplete or wrong or there is something we have not taken into account, for instance something like dark matter.
No we don't, we infer the presence of dark matter by accounting for the differences between what GR predicts and what we measure.
But what is the pressure a function of?
You're saying the physicists who wrote that article are wrong, and that it's not possible to have negative pressure with a positive energy density?
In fact there was recently some more direct evidence for the presence of dark matter, involving a cluster of dark matter (seen by gravitational lensing) that had overshot the matter it was associated with and was thus in a somewhat different position. See here for a good summary.
Almost all observation is accomplished in such a manner, i.e. we don't directly observer something, we indirectly observe it. And we do so in as many ways that we can. When our observations are consistent with our theory of what is going on then it is said that evidence has been provided. Something important to understand in physics is that it is not the goal to prove things in physics.
Have you ever observed an electron? If not then how do you know they exist? :biggrin:
Pete
  • · Replies 21 ·
  • · Replies 145 ·
21K
  • · Replies 64 ·
9K
