Coordinate transformation formula in Zee's Einstein Gravity
11 replies · 3K views · last reply
Keita
TL;DR
A question about 1. 6. Curved Spaces: Gauss and Riemann
In p. 84, Zee says “In the new coordinates, M is replaced by M’ = R[-1]MR.” However, I figure out M is replaced by M’ = RMR[-1]. Why is M replaced by M’ = R[-1]MR?
Can you show your work?
In addition, you shouldn’t assume that your reference is easily accessible. Show more context (preferrably using MathJax).
Indeed, how did you figure? Look at the expression for z on top of page 84, apply the rotation R to the vector x and use RT = R-1. As such the rotation on x can be identified as a transformation of the matrix M (like in quantum mechanics).
##R^T##
Thank you for your suggestion. Let me confirm I understood your explanation correctly.
Does your suggestion mean the following?
$$ z \sim \frac{1}{2} \vec{x}^{T} M\vec{x} $$
(Top of page 84)
z \sim \frac{1}{2} \left(R\vec{x}\right) ^{T} M\left(R\vec{x}\right)
\frac{1}{2}\vec{x}^{T}R^{T}MR\vec{x}
\frac{1}{2}\vec{x}^{T}R^{-1}MR\vec{x}
(Applying the rotation R to the vector x and using ## R^{T} = R^{-1} ##)
Therefore, ## M' = R^{-1} M R ##.
Keita said:
##R^T##
(Top of page 84)
Yes.
haushofer said:
Yes.
Thank you for your answer. I understood your suggestion correctly. Now, let me show you my argument.
In the original coordinate, we have the following.
$$ z \sim \frac{1}{2} \vec {x}^{T} M\vec {x} (1)$$
(Top of page 84)
In the rotated coordinate, we have the following.
z \sim \frac{1}{2} \vec{x'}^{T}M' \vec{x'}
\frac{1}{2} \left(R\vec{x}\right) ^{T} M'\left(R\vec{x}\right)
\frac{1}{2}\vec{x}^{T}R^{T}M'R\vec{x}
\frac{1}{2}\vec{x}^{T}R^{-1}M'R\vec{x}(2)
From (1) and (2), we have the following.
R^{-1}M'R=M (3)
Therefore,
M'=RMR^{-1}(4)
What do you make of my argument?
(Top of page 84)
R^{-1}M'R=M (3)
Therefore,
M'=RMR^{-1}(4)
You say that after the coordinate transformation, you get
But why the prime on M? You apply the rotation to the coordinates, not to the matrix elements of M, right? So I'd say that afther the coordinate transformation,
z \sim \frac{1}{2} \vec{x'}^{T}M \vec{x'}
In other words: you should carefully think about on what the transformation is applied to.
Sorry for the delay of my response. I appreciate your explanation. Still, I would like to stand to my argument.
In the original x-y coordinate,
z = \frac{1}{2}ax^2 + cxy + \frac{1}{2}by^2 = \frac{1}{2} \vec{x}^{T} M \vec{x}.
M = \begin{pmatrix}
a & c \\
c & b
\end{pmatrix}.
(pages 83 and 84)
In the rotated u-v coordinate,
z = \frac{1}{2}a'u^2 + c'uv + \frac{1}{2}b'v^2 = \frac{1}{2} \vec{x'}^{T} M' \vec{x'} = \frac{1}{2} (R\vec{x})^{T} M' (R\vec{x}) = \frac{1}{2} \vec{x}^{T}R^{T}M'R\vec{x} = \frac{1}{2} \vec{x}^{T}R^{-1}M'R\vec{x}.
\vec{x'} = \begin{pmatrix}
u \\
v
\end{pmatrix}.
M' = \begin{pmatrix}
a' & c' \\
c' & b'
\end{pmatrix}.
\vec{x'} = R \vec{x}.
(page 84)
Since ## z = z ##, we have the followings.
M = R^{-1}M' R.
M' = R M R^{-1}.
I hope you would response to my argument.
@Keita what you have noticed is the distinction between what are sometimes called "active" vs "passive" transformations.
Passive: If you view the transformation as rotating the (x-y axes of) the coordinate system, but keeping the vectors themselves fixed, then the position vector and the matrix have new components in the new coordinate system and ##z' = \tfrac{1}{2}(\mathbf{x}')^T M' \mathbf{x}' = \tfrac{1}{2} \mathbf{x}^T R^T M' R \mathbf{x}##, leading to ##M' = R M R^T## after setting ##z' = z##.
Active: if you view the transformation as rotating the vector ##\mathbf{x} \mapsto R\mathbf{x}##, but keeping the coordinate system fixed, then obviously ##\mathbf{x}'## has different components to before but the matrix ##M## is unchanged. Then ##z = \tfrac{1}{2} (\mathbf{x}')^T M \mathbf{x}' = \tfrac{1}{2} \mathbf{x}^T R^T M R \mathbf{x}##. You could view this instead as a transformation of the operator itself as ##M \mapsto M' = R^T M R##.
The two different versions of ##M'## are related by transpose (because as you should be able to see: rotating the coordinates ##n## degrees clockwise is the same as rotating the vectors ##n## degrees anti-clockwise. )
M = \begin{pmatrix}
a & c \\
c & b
\end{pmatrix}.
(pages 83 and 84)
u \\
v
\end{pmatrix}.
a' & c' \\
c' & b'
\end{pmatrix}.
(page 84)
M = R^{-1}M' R.
M' = R M R^{-1}.
I agree with your argument and your result ##M' = RMR^{-1}##.
Zee uses the rotation matrix ##R## to induce a coordinate transformation ##\mathbf{x}' = R \mathbf{x}##. So, this is an example of a passive transformation as described by @ergospherical. His ##M' = RMR^T = RMR^{-1}## agrees with your result.
Also, look at Zee's equation (17) on page 72 which shows how the matrix ##g## for the metric transforms under a general coordinate transformation ##S## : $$g'(x') = (S^{-1})^T g(x) S^{-1}.$$ For the special case where ##S## is a rotation ##R##, this becomes $$g'(x') = (R^{-1})^T g(x) R^{-1} = Rg(x)R^{-1}.$$ This has the same form as you derived for the matrix ##M##.
Thank you. I appreciate your suggestion.
Thank you for your suggestion. I also appreciate your note on Zee’s equation(17) on page 72.
