Finding other trig functions when cosθ=-4/5 in quadrant 3
  • Thread starter land_of_ice
    Trig
land_of_ice
The problem is: cosθ=-4/5 θ in quadrant 3
and they ask that you find the exact value of the remaining trig functions,
I do not know all of the relevant things to do, which is why I have a question, about what they are basically, as far as quadrant is concerned, the sign of the answer and whether or not it matters that a picture is drawn and used or not.
I got the exact opposite signs to my answer, as the book got, but the values were correct, also I don't know why but after doing about 15 of these problems, when I drew the picture (first step), the θ seemed to be in the same area of the unit circle every time , in quadrant 1, so how can you tell where θ is supposed to be? Also, after I drew the picture, I never use it in the equation, I just plug in values for either r, x , or y (whichever are given in the original problem) into the Pythagorean theorem. and then solve for the other variable, and then set up the r/x , r/y etc for the remaining trig functions.
(One other thing, about θ always being in quadrant one, the way I perceived it, is that in a related problem such as sinθ = -3/5 and cosθ=4/5 , it doesn't tell you what quadrant to put θ in so how do you determine this? )
hi land_of_ice! :smile:
if you never used the picture, then of course you got it wrong! :rolleyes:
there's always two answers for any cos or sin equation …
if cosθ is positive, then θ can be in quadrants 1 or 4; if cosθ is negative, then θ can be in quadrants 2 or 3 …
there is no way of knowing unless you are told in the question!
Hey Tim, thanks for that , it was very helpful :)
Since you are told that this is in the third quadrant, One way to do this, since cosine is "near side over hypotenuse", is to draw a line from the origin of a coordinate system to (-4, 0), then a line down to (-4, -3) (you know the "opposite side" has length 3 by the Pythagorean theorem). Now sine is "opposite side over hyptenuse" or -3/5 (the hypotenuse in such a picture is always positive), tangent is "opposite side over near side" or -3/-4= 3/4, etc.
If you are told that sin θ= -3/5 and cosθ= 4/5, then the "near side" is positive 4 so draw a line from the origin to (4, 0). The "opposite side" is negative 3 so draw a line from (4, 0) to (4, -3). That will be in the fourth quadrant. tangent and cotangent will be negative (specifically, -3/4 and -4/3), secant positive (5/4), and cosecant negative (-5/3).
