Plotting streamlines for velocity field u = xi - yj
4 replies · 11K views
elle
Graph function help please - fluid mechanics/streamlines related
I'm not too sure whether I should have posted this in the Physics section or in the maths :confused: Please move this topic if its in the wrong place!
this probably seems like a silly question but is it possible to plot x*y + c on a graph where c = a constant? :confused: I'm working on a question on fluid mechanics where I have to find the streamfunction and plot the stream lines. However I'm in doubt whether i have done the question correctly in the first place.
Please help!
For the 2D velocity field u = xi - yj find the streamfunction 'psi' (apologises, I'm not too familiar with Latex)
given above
After partially differentiating and using formulas from my notes, i got psi = x*y + c :confused:
What do you mean by "plot x*y+ c". That's neither a function nor an equation. If you mean xy= c or xy+ c= 0, then, yes, of course, you can plot it- it's a family of hyperbolas.
Please help!
Then [itex]\nabla \psi= x\vec{i}- y\vec{j}[/itex], right?
So
[tex]\frac{\partial \psi}{\partial x}= x[/tex]
and
[tex]\frac{\partial \psi}{\partial y}= -y[/itex]<br /> That should be easy to integrate.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <h2>Homework Equations</h2><br /> <br /> given above<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> After partially differentiating and using formulas from my notes, i got psi = x*y + c <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":confused:" title="Confused :confused:" data-smilie="5"data-shortname=":confused:" /> </div> </div> </blockquote> Perhaps I am misunderstanding your "stream function". I get the orthogonal family to xy= C which would be the potential function.[/tex]
You are confusing "stream function" with "velocity potential", HallsofIvy!
A stream function may always be defined if the velocity field is solenoidal, i.e, [tex]\nabla\cdot{\vec{v}}=0[/tex]
In the 2-D case, we may define: [tex]\vec{v}=\nabla\times\psi\vec{k}[/tex], where [itex]\psi[/itex] is the scalar stream function.
The analogue in electro-magnetism is called the magnetic vector potential, I believe..
Very likely- it's been a long time since I have looked at fluid dynamics.
So the equations are
[tex]\frac{\partial \phi}{\partial x}= y[/tex]
and
[tex]\frac{\partial \phi}{\partial x}= x[/tex]
Yes, that tells us that [itex]\phi(x,y)= xy+ c[/itex].
Since the stream lines (again, if I remember correctly!) are the lines on which [itex]\phi[/itex] is a constant they are given by xy+ c= c' or xy= C, the hyperbolas that my family, [itex]x^2- y^2= c[/itex] are orthogonal to.
elle, perhaps your only problem was not realizing that you get an equation to graph by setting your solution for [itex]\phi[/itex] equal to a constant.
and
ohh yeah! I forgot that its equal to a constant :redface: Thanks guys for the help :smile:
