Proving centroid distance relations for triangle ABC
13 replies · 3K views · last reply
matrixone
If G be the centroid of ΔABC and O be any other point, prove that ,
## 3(GA^2 + GB^2 + GC^2)=BC^2+CA^2+AB^2##
##and,##
##OA^2 + OB^2 + OC^2 = GA^2.GB^2+GC^2+3GO^2##
i m practising from S L LONEY coordinate geometry first chapter ... only the equation that i used to solve is mentioned in the chapter...
i felt that co ordinate geometry approach will be cumbersome ...
so i started with
##GA^2 + GB^2 = AB^2+2.GA.GB.cos∠AGB##
and similar 2 more equations
But i am stuck here ! :(
And for the 2nd question i can't even get a start ...
Please help me with a hint ...
[/B]
If you have a triangle ABC and drop a median from A to A', the midpoint of BC, what is the relationship between the lengths AB, AC, AA' and BA'(=CA')?
I can't find any sir... : ( ...definitely , ΔABA' and ΔACA' are not similar ...
are you referring to the same cosine rule that i used ?
No. It is a result I dimly recall from my own schooldays, so I thought you may have encountered it in your book.
Drop a perpendicular from A to BC meeting it at P. Call AP length h and PA' length x. What three equations can you write relating these to AB, AC etc. using Pythagoras' Theorem?
Triangle ABC with vertices A at the top, B at the lower left and C at the lower right. A segment from A meets side BC at A', with the labels x and p marking the parts of BC either side of A'. A dashed perpendicular h runs from A to side BC, marked with a right angle.
BP2 + h2 = AB2
PC2 + h2 = AC2
x2 + h2 = AA'2
matrixone said:
BP2 + h2 = AB2
PC2 + h2 = AC2
x2 + h2 = AA'2
There's a mistake in the first one, probably just typed wrongly.
You need to get rid of PC. What is the relationship between PC, x and A'C?
Next manipulate the equations to eliminate x2 and h2.
so i started with
GA2+GB2=AB2+2.GA.GB.cos∠AGBGA2+GB2=AB2+2.GA.GB.cos∠AGBGA^2 + GB^2 = AB^2+2.GA.GB.cos∠AGB
Pick a triangle of verticies ##(0,0), (a,0), (x,y)## then ##G = \left({a + x \over 3}, {y\over 3}\right)
##. Now you evaluate LHS of first equation and then RHS. It is not that cumbersome.
For the second draw the figure and use cosine rule.
Triangle ABC with vertices A, B and C, centroid G and circumcentre O marked, with triangle OGC shaded red.
Use cosine rule on the vertex G of the red triangle. I am not sure it will work though.
that was optimistic choice of vertices. I solved it that way (by comparing coefficients) and yes, not too cumbersome. thanks :)
I can't see any mistake in the first one sir.. : ( ...and by changing PC = A'C - x , from last two equations i am able to get an expression for x (a big one) and then using that value to get expression for h seems even a time consuming approach .(Buffu's solution seems better)... And i can't see were this leads to the actual problem ...Or, were you thinking in some other way ?
matrixone, how did you do the second one ? I tried but am stuck on cosines.
Sorry, I thought I replied to this... No, you are right, I misread something.
I can solve this but my method is too primitive to do.
No, you should get quite a simple relationship between AB, AC, A'B and AA'. Please post your working.
It is a well-known theorem.
Once you have that, the original problem is quite easy.
