Why does a dropped stone appear to fall in a parabolic curve to a stationary observer?
  • Level: Undergrad
  • Thread starter Thread starter nadja
    Fall
10 replies · 3K views
nadja
"I stand at the window of a railway carriage which is travelling uniformly, and drop a stone on the embankment, without throwing it. Then, disregarding the influence of the air resistance, I see the stone descend in a straight line. A pedestrian who observes the misdeed from the footpath notices that the stone falls to earth in a parabolic curve. I now ask: Do the "positions" traversed by the stone lie "in reality" on a straight line or on a parabola? Moreover, what is meant here by motion "in space" ? From the considerations of the previous section the answer is self-evident."
This is a quote from
Albert Einstein: Relativity
Part I: The Special Theory of Relativity, Space and Time in Classical Mechanics.
Could someone please explain to me why, to the pedestrian, the stone falls in a parabolic curve and what type of parabolic curve it is? thank you
Well, the vertical motion is proportional to y**2 (for both observers) and the horizontal motion in the reference frame of the pedestrian is proportional to the speed of the train , which is linear.
SO ... if it is indeed a parabola (and I haven't checked that but if it's what you read, it's likely correct) then I can only assume that if you combine the two motions and calculate the loci, you get the equation for a parabola.
What do you mean, what kind of parabolic curve?
You are assuming that one of the two frames of reference gives some kind of absolute truth, which is a false assumption. The answer to "how is the motion really described" is "it depends on your frame of reference." Neither one is absolute. All motion is relative.
To the pedestrian, the stone is initially traveling with some horizontal velocity, let's call it Vx, and zero vertical velocity, let's call it Vy. Gravity begins to accelerate the stone downwards at a rate of about 9.8 m/s2, while the horizontal velocity remains the same.
If we graph the velocities vs time, we see that since Vx remains constant and Vy accelerates at a rate proportional to time squared, the two combine to make a parabola. In other words, the equation that defines the trajectory is that of a parabola.
I think that should be t2, not y2.
ohh ok i got it!! thank you very much for the explanation! I'm not too good at physics.
what would t^2 and y^2 mean here?
Those are variables, where t is time and y is the vertical position coordinate.
This is about Newtonian dynamics/kinematics. We can explain this in two different ways:
(a) The point of view of Einstein in the train:
He uses Cartesian coordinates ##(x',y',z')## with the ##z'## axis pointing upwards. The equation of motion is
$$m \ddot{\vec{x}}'=-m \vec{g}=-m (0,0,g).$$
Einstein drops the stone initial at rest from ##\vec{x}_0'=(0,0,h)##. By integrating twice he finds
$$\vec{x}'(t)=-\vec{g}{2} t^2 + \vec{x}_0'=(0,0,h-g t^2/2).$$
The trajectory from Einstein's point of view is a straight line down.
How does the pedestrian on the embankment describe this? He uses coordinates
$$\vec{x}=\vec{x}'+\vec{v} t,$$
where ##\vec{v}=\text{const}=(v,0,0)## is the velocity of the train relative to him. So he describes the motion of the stone by
$$\vec{x}=(v t,0,h-g t^2/2),$$
which is a parabola. This becomes more obvious by describing the trajectory in the form ##z=f(x)##. To that end you simply eliminate time by ##x=v t## or ##t=x/v##:
$$z=h-g t^2/2 = h-g x^2/(2 v^2),$$
which obviously is a parabola in the ##(x,z)## plane.
(b) The point of view of the pedestrian
He describes the motion of the stone by the same equation as einstein,
$$m \ddot{\vec{x}}=-m \vec{g}=-m(0,0,g).$$
But now from his point of view the initial conditions are ##\dot{\vec{x}}(0)=\vec{v}=(v,0,0)##, ##\vec{x}(0)=\vec{x}_0=(0,0,h)##. Which gives
$$\vec{x}(t)=-\vec{g} t^2/2 + \vec{v} t +\vec{x}_0=(v t,0,h-g t^2/2),$$
which is the same result we got using Einstein's point of view.
The pedestrian will also conclude rightly what Einstein observes. He just uses the inverse transformation,
$$\vec{x}'=\vec{x}-\vec{v} t=(0,0,h-g t^2/2),$$
which is also the same as Einstein gets by solving the initial-value problem using his coordinates.
The parabola or straight line behavior that Einstein describes is an example of Galilean relativity (worth googling). Galilean relativity was, until Einstein developed special relativity, presumed to be the right mathematical relationship between positions described by observers moving relative to one another; as we might guess from the name, it was formalized by Galileo so has been around for a very long time.
Basically special relativity and the Lorentz transformation replaced Galilean relativity and the Galilean transform.
