Solving log(x³) = (log x)² and combining logarithmic expressions
  • Thread starter Elus
    Log
13 replies · 5K views · last reply
Elus
Problem 1:
Solve log(x^3) = (log(x))^2 for x.
Note, there are two solutions, A and B, where A < B.
A = ?
B = ?
Problem 2:
Rewrite the expression 2log(x)-2log(x^2+1)+4log(x-1) as a single logarithm log A.
A = ?
2. The attempt at a solution
Problem 1 Attempt:
I might be able solve this graphically by plotting y1 = log(3^x) and y2 = (log(x))^2 and finding the points of intersection.
However, I'd like to do this by hand, if possible! Would I start by raising both sides to e?
e^log(x^3) = e^(logx)^2
then
x^3 = e^2
then
x = (e^2)^(1/3)
x = e^(2/3)
x = 1.947734
Wolfram-alpha says otherwise :( and there are supposed to be 2 solutions. I only got one D:
Problem 2 attempt:
Okay, I tried using properties of logarithms here.
2log(x) - 8*log(x^3 - x^2 + x - 1) <------- Since the 2 logs are added, you can
multiply the insides of the logs together, right?
16*log(x/(x^3-x^2+x-1)) <------------ Since the 2 logs are subtracted, you can
divide them, right?
For 1) [tex]e^{log(x)^2}\neq e^2[/tex]
and there's a simpler way to solve this problem anyway, if you let y=log(x) then substituting this into the equation [tex]log(x^3)=(log(x))^2[/tex] will give?
For 2)
Well this is like saying [tex]a.log(b)+c.log(d)=ac.log(bc)[/tex] this isn't right. If you have a.log(b) then this is equivalent to log(b^a).
divide them, right?
Again, not right because you have made the same mistake as before.
For 2)
For problem 1:
log(x^3) = y^2 <---Substitute y=log(x) on right side
3*log(x) = y^2 <----- You said log(b^a) = a.log(b), so that's what I applied.
3*y = y^2 <----- substitute y=log(x) on left side
3 = y <----divide both sides by y
3 = log(x) <-----substitute back log(x) for y
x = e^3 <---------raise both sides by e
x = 20.085536
Great, that's one answer, but it said that there is are two answers (A and B). Where do I get the other answer from?
For problem 2:
Okay, so I need to bring the 2, 2, and 4 into the log function?
log(x^2)-log((x^2+1)^2)+(log(x-1)^4)
Before I spend a time solving the ugly problem above, can someone let me know if this going in the right direction?
Elus said:
For problem 1:
x = 20.085536
Yes I'm glad you were able to apply all the formulae correctly :smile:
Remember back when you were learning quadratics that when you have something like [tex]x^2-x=0[/tex] rather than dividing through by x you factored out x to get [tex]x(x-1)=0[/tex] which then gave you the two solutions x=0,1. When you divide through by x you lose the solution x=0 because it is assuming x does not equal 0 (since you can't divide by 0). Do the same for this problem.
Elus said:
For problem 2:
Yes that's exactly right. And you don't need to expand, leaving it in factored form is enough when applying the log(a)+log(b)=log(ab) rule.
Elus said:
For problem 1:
x = 20.085536
Be careful. "log" generally assumes [itex]log_{10}[/tex] whereas "ln" assumes [itex]log_e[/tex][/itex][/itex]
zgozvrm said:
Be careful. "log" general assumes [itex]log_{10}[/tex] whereas "ln" assumes [itex]log_e[/tex][/itex][/itex]
[itex][itex] <br /> In maths, the syllabus usually gives the student a chance to work with all types of log bases when starting off, but once they have a firm grip of this they imply all expressions of log are of the base e, unless specifically stated.[/itex][/itex]
That's why I said "generally!"
Still, I'm betting that the question, as posed, is referring to [itex]log_{10}[/tex] rather than [itex]log_e[/tex] for 3 reasons:<br /> 1) the expressions used "log" rather than "ln"<br /> 2) scientific calculators have "log" buttons that work with [itex]log_{10}[/tex] and "ln" buttons the work with [itex]log_e[/tex] <br /> 3) in this case, using [itex]log_{10}[/tex] results in nice, tidy integer answers<br /> <br /> Of course, you can use any base you want and come up with answers that work. But, I'm betting that the point of the problem had more to do with rearranging the equation to solve for X than than anything else.[/itex][/itex][/itex][/itex][/itex]
Yes I noticed you said generally but that's what I'm arguing. In the world outside theoretical maths, it is generally log10 but in the maths classroom you will find that log is considered loge unless otherwise stated.
I myself got so used to this after doing tons of log questions in class that when logs were introduced into a formula in physics I of course made the mistake of using loge rather than log10.
Apparently, we're arguing the same thing. I simply told the OP to "be careful" because "log" can be interpreted different ways. I don't know what kind of class he is in, or what level (or what country, for that matter), and therefore, I wouldn't assume one base or the other without more information.
In high school, however, my experience is that "log" by itself is assumed to be the common logarithm, ie. base 10. "Ln" is used for base e. This is what I've also seen in some Precalculus textbooks. This is high school in the US.
... which is why I pointed this out to the OP
(Thank you, eumyang!)
I guess this shows how high schools work in different parts of the world. Thanks eumyang.
(That's why I said "generally!")
You actually said general, but that's beside the point.
Well yeah it is, so why did you bring it up :-p
