Why does 2|A×B| equal |A×B - B×A|?
5 replies · 3K views · last reply
Mosaness
1. See attached image please!
2. For part (a), I applied the cross product and got (-6i - 2k) for ([itex]\vec{A}[/itex]x[itex]\vec{B}[/itex]. I got (6i + 2k) for ([itex]\vec{B}[/itex] x [itex]\vec{A}[/itex]).
For part (b), [itex]\vec{C}[/itex] was simply (-6i - 2k) - (6i + 2k) = (-12i -4k).
For part (c), the magnitude of [itex]\vec{C}[/itex] was simply 12.65 and for the magnitude of two times ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]) is 12.65. So they are equal. But WHY? I can prove it mathematically, but I'm having some trouble with this.
I do think that it is because ([itex]\vec{A}[/itex]x[itex]\vec{B}[/itex] is equal in magnitude but opposite in direction to ([itex]\vec{B}[/itex] x [itex]\vec{A}[/itex]), therefore, the magnitude for 2 times ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]) ought to equal the magnitude of ([itex]\vec{C}[/itex])
  • Typed homework problem on unitless vectors A = i + 2j - 3k and B = i - 3k, with parts a to d asking for cross products A×B and B×A, vector C = A×B - B×A, and why |C| equals 2|A×B|.
I do think that it is because ([itex]\vec{A}[/itex]x[itex]\vec{B}[/itex] is equal in magnitude but opposite in direction to ([itex]\vec{B}[/itex] x [itex]\vec{A}[/itex]), therefore, the magnitude for 2 times ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]) ought to equal the magnitude of ([itex]\vec{C}[/itex]) (
You are right the cross product changes sign when you change the order of the vectors, but the magnitude stays the same. Think how the cross product was defined: AxB is a vector perpendicular to both A and B and it points in the direction from where the rotation of the first vector into the second looks anti-clockwise. So AxB=P and BxA=-P. If you subtract -P it is the same as adding P.ehild
I was doing part (d.) and the unit vector for [itex]\vec{C}[/itex] was (-0.949i - 0.316k) and the unit vector for ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]) was also (-0.949i - 0.316k). Therefore, the unit vector for [itex]\vec{C}[/itex] is not twice as long as the unit vector for ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]). Instead, it is equal. Why is it equal? I'm not quite sure. But if I had to guess, I would say that for vector C, the vector was twice that of ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]), as was the magnitude. And for ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]), the vector and magnitude for half of that for vector C, therefore, when the unit vector was found, they were equal to one another. Had the magnitude of ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]) been half that of vector C, THEN the unit vector for ([itex]\vec{A}[/itex] x [itex]\vec{B}[/itex]) would have been half that of vector C.
The magnitude of a unit vector is 1. It is the definition of the unit vector: a vector pointing in a specific direction, and having unit length (magnitude).
ehild
Uh, I think you're overthinking this. What is the magnitude of any unit vector?
Well the magnitude will always be one. I WAS over thinking it! Oops
