Finding the distance to an Asteroid
  • Context: Undergrad
  • Thread starter Thread starter dimensionless
    Asteroid
Astronomers determine the distance to an asteroid from the sun by assessing its intrinsic brightness and proper motion, which aids in calculating its orbit and position. Initial observations require precise recording of time, elevation, azimuth, range, and range rate, often utilizing signal bouncing for accurate measurements. The Doppler shift provides velocity data, while subsequent observations refine trajectory predictions. This process explains why early warnings about potential asteroid impacts may later be deemed false alarms as more data becomes available.
  • Understanding of intrinsic brightness and its role in distance measurement
  • Familiarity with proper motion and orbital mechanics
  • Knowledge of Doppler shift and its application in velocity calculations
  • Experience with observational astronomy techniques and data recording
  • Research methods for measuring intrinsic brightness of celestial bodies
  • Learn about orbital mechanics and trajectory plotting techniques
  • Explore the use of radar ranging in asteroids and other celestial objects
  • Study the implications of Doppler effect in astronomy and its applications
Astronomers, astrophysicists, and students interested in celestial mechanics and asteroid tracking will benefit from this discussion.
dimensionless
When astronomers find an asteroid, how do they determine its distance from the sun? And for that matter, how do they determine its absolute velocity.
Astronomy news on Phys.org
That's tricky one. They have to know its intrinsic brightness in order to know its distance. They guess, based on known bodies.
After more observation, they can determine its proper motion, which will help in determining its orbit, which will help in determining its position/distance.
All these factors work together to narrow down the range as they receive more data.
But, as one will note, in the study of planet 10 (I can't bring myself to call it Xena), they don't know its size very well at all, since they have no yardstick to measure its brightness. They also haven't had very long to determine its orbit accurately (which is > 250 years long).
You take several observations.
Specifically, each observation has to record the time, elevation, azimuth, range, and range rate. The range and range rate could be found by bouncing a signal off of the object. The time it takes the signal to return tells you how far away the object is. The Doppler shift in frequency tells you how fast the object is approaching or departing. If you can't bounce a signal off the object, you have to estimate the range and range rate by other means (brightness, etc).
Since the object is unlikely to have moved very far in one night from the observer's perspective, it's hard to make 'several' observations very quickly and the accuracy of the range and range rate usually aren't very good on the first observations. This is why you periodically get a warning of an asteroid that may hit the Earth at some date in the future.
The initial observations are just to give other astronomer's the objects location. Eventually, you have enough observations to plot a trajectory through the sky. Having lots of observations and plotting them out is the only accurate way to determine the object's distance and velocity (just like calculating a lot of answers for various values of x eventually gives you a curve or line that defines an equation).
It's also why eventually the warning about the asteroid that may hit the Earth is discovered to be a false alarm. A wide swath of possible trajectories is eventually narrowed down to the object's actual trajectory.
  • · Replies 30 ·
