Determining Causal/Non-Causal System in Discrete Signals
  • Thread starter Thread starter LM741
The discussion revolves around determining whether discrete signal systems are causal, memoryless, and time-invariant. Participants explore specific examples of systems and express confusion regarding the definitions and implications of causality in relation to system equations.
  • One participant questions the causality of the system represented by the equation y[k+1] + 2y[k] = x[k+1] + x[k], noting that it appears to advance in time.
  • Another participant suggests that by changing the variable to k+1 = j, the equation can be reinterpreted to show dependence on present and past inputs, thus supporting its causality.
  • Confusion arises regarding the interpretation of past values, particularly with terms like x[k-1], and how they relate to the concept of causality.
  • Participants discuss whether the presence of future output terms, such as y[k+1], affects the causality of the system.
  • One participant proposes a systematic approach to analyze the system by making y[k] the subject of the formula, while others suggest that prediction does not inherently make a system non-causal.
  • There is a suggestion that the system can be viewed in a predictive mode without losing its causal nature.
Participants express differing views on the causality of specific systems, particularly regarding the role of future output terms. While some assert that the systems discussed are causal, others remain uncertain or confused about the implications of their structures.
Participants express confusion about the definitions of causality and how to apply them to more complex systems. There are unresolved questions about the interpretation of terms and the implications of future output values on causality.
This discussion may be useful for students and practitioners in signal processing, control systems, or related fields who are grappling with the concepts of causality and system analysis in discrete signals.
LM741
hey guys.
anybody know how to tall if a system is causal, memoryless, time invariant...
a system like this for example: y[k+1] + 2y[k] = x[k+1] + x[k]
this is causal (according to my notes) but i can't see why because here we are advancing in time! System is causal if output depends only on past and present input signal!
i know how to determine a simple system like
y(t) = x(t-5)
just not sure how to handle a more comple system like that above?
also: 2y[k+1] + y[k] = 2kx[k] + x[k-1] +3
so confused!
thanks
working with discrete signals by the way...
LM741 said:
hey guys.
y(t) = x(t-5)
so confused!
thanks
If you make a variable change k+1 = j in the first example, you have:
y[j] + 2y[j-1] = x[j] + x[j-1], which depends only on present and past inputs.
In the second example you have only present and past inputs. You have a prediction of the value of the output, but there is no problem here.
A non causal system would be for instannce:
y[k] - y[k-1] = x[k+1] + kx[k]
This system is noncausal, since the value of the ouput at present depends on the value of the input in the future.
SGT>>thanks..just one more thing
SGT>> thanks very very much! appreciate it---just not entirely sure what you mean with the second example...
do i look at all the input terms and all the output terms separately?
is a 'past value' a delay in time? like x[k-1]?
looking at it from a graphic point of view how do you view this as a past value?
i know x[k-1] is a shift to the right (by one unit) - but how do you visualize that to be a past value? always had trouble grasping this concept...
The way i look at it is: you sampling from the left of the graph (as time passes you move along to the right) now applying x[k-1] will cause the entire graph to shift to the right by one unit thus it is one unit further away from you thus it has been delayed. how is this a past value because you haven't got to it yet - it is still in the future? really weird hey? sorry I am getting really confused here.
is this right or is my perception distorted ? :-)
would really appreciate any feedback
thanks
john
Drat. Judging by the title, I thought this thread was going to be about business attire...:biggrin:
thanks
john
If your sampling period is T and [tex]t_k[/tex] is yor actual instant, [tex]t_{k-1} = t_k - T[/tex], or one sample period in the past, while [tex]t_{k+1} = t_k + T[/tex] or one sample period in the future.
x[k] is a short notation for [tex]x[t_k][/tex], so x[k-1] and x[k+1] are respectively the values of the variable x one sample period in the past and in the future.
SGT>>thanks a a lot! appreciate it
one LAST thing:
isn't this system causal??
because the value of my output at present (i.e. y[k]) is equal to past and present values of my input (i.e. x[k] and x[k-1]) ...just not sure how to handle the output at a futre value (y[k+1]) and the constant term 3?
is it non casual because ofthe y[k+1]?
is there any systematic approach to solving such a system? like making y[k] the subject of the formula and then evaluating it?
thanks so much for your time!
John
You are absolutely right, make y[present] the subject of the formula.
For
perform a change of index with n = k+1 so that
2y[n] + y[n-1] = 2kx[n-1] + x[n-2] +3
and then you'd clearly see that the present output y[n] depends on the previous inputs, x[n-1] and x[n-2], and also a previous output y[n-1].
so i first change the index and then make y[n] the subject of the formula?
so the system is causal...right?
thanks doodle!
thanks doodle!
You don´t really have to change the variable. You can work the system in prediction mode and estimate the future output based on the present output and on present and past inputs.
The fact that you use prediction does not make the system noncausal.
Think, for instance of the movement of a particle with constant velocity.
The position x at instant k+1 depends on it´s position and velocity at instant k:
x[k+1] = x[k] + T.v[k], or x[k+1] - x[k] = T.v[k].
If the velocity is not constant, and you don´t know the acceleration, you can use the average velocity at the previous time interval:
[tex]v_{avrg}=\frac{v[k] + v[k-1]}{2}[/tex], so
x[k+1] - x[k] = T.v[k]/2 + T.v[k-1]/2
thanks sgt. the system 2y[k+1] + y[k] = 2kx[k] + x[k-1] +3
is causal then? it has to be !?
thanks
thanks
You have understood. It is causal and is predictive.
thanx...SGT
...And a thank you to SGT from me ! ;)
18K
  • · Replies 456 ·
32K
  • · Replies 43 ·
