How do you use Java's Hashtable?
  • Context: Java
  • Thread starter Thread starter 0rthodontist
The discussion revolves around the use of Java's Hashtable and HashMap classes, focusing on how to effectively utilize these data structures with object keys, particularly in the context of Comparable objects. Participants explore the mechanics of hashing, the implementation of hashCode, and performance issues encountered when using these collections.
  • Homework-related
  • One participant expresses confusion about how Java's Hashtable and HashMap work with object keys, particularly regarding the mapping of Comparable objects and the use of hash codes.
  • Another participant clarifies that all objects in Java have a hashCode method, which can be overridden to provide a custom hash value.
  • It is noted that integers can be used as keys since they are objects, but the Integer wrapper class must be used instead of primitive int.
  • A participant suggests that overriding the equals method necessitates also overriding the hashCode method to maintain consistency.
  • Concerns are raised about the efficiency of using a hash map, particularly when a CubeState class's hashCode is defined based on its string representation, leading to performance issues.
  • Another participant suggests that using a HashSet might be more appropriate than a HashMap for the participant's needs.
  • Participants discuss the implications of initializing a hash table with a large size versus the default size, with differing opinions on the best approach.
  • There is a suggestion that the performance issue may be due to the creation of a new hash map in a loop, which could be avoided by making the hash map a static member of the class.
  • One participant finds that switching from HashMap to HashSet resolves the performance issues, indicating a misunderstanding of the differences between these two data structures.
Participants express a mix of agreement and disagreement on various points, particularly regarding the implementation of hashCode, the choice between HashMap and HashSet, and performance considerations. The discussion remains unresolved on the best practices for using these data structures effectively.
Some participants mention performance issues related to the use of hash maps, suggesting that the efficiency may depend on how the hashCode is implemented and how the data structures are utilized within loops. There is also uncertainty about the optimal size for initializing hash tables.
Java developers, particularly those working with data structures, object-oriented programming, and performance optimization in Java applications.
0rthodontist
I need a hashtable, but I can't seem to figure out how Java's Hashtable or HashMap classes are supposed to work. The keys in these classes are objects, not numbers. How does that even work? The only thing I can think is that the addresses of the keys (which are objects) are mapped to integer hash keys, which is not what I want at all. The problem is that I have a load of Comparable objects and I want to check to see if I've already used one of them, based on the compareTo method for the objects. What I optimally want is something like this:
--I associate a number to each of my objects, which are equal iff one object equals() the other. I do not worry about the suitability of such numbers for hash keys--in particular I don't want to worry about the range of keys.
--something in the Java library produces good hash keys based on these numbers (not on the addresses of Integers containing the numbers) and uses those keys to index my objects in a hash table
I would like to just feed the hash table Integers containing the essential information about the objects and have it do the rest for me, but since the hash table accepts general objects, I'm worried that it won't index the Integers by their contents.
Technology news on Phys.org
The java API documentation is actually very good -- you should get a copy.
All objects have a hashCode method -- that's how it obtains a hash value for your object. If you don't like the default implementation (which does hash the address, as you guessed), then provide your own implementation!
Hashtables in java are more generic than what one normally thinks of hashtables as. So instead of key being just numbers, you can use any object. Btw, integers are also objects so you can use them normally as you would (though you would need the "Integer" wrapper class instead of the normal "int").
-- AI
P.S -> hash.put(new Integer(5), new Blah());
I have been reading the API. Ok, so is this how it works?
My object -> Integer "key"
Integer -> hashCode int (equal to the value stored in the Integer)
hashCode -> index in Hashtable
Right; Integer.hashCode() is based on the value contained in the integer, and not the address.
Oh, one more thing...
Anytime you override the equals, you're really supposed to also override hashCode to agree with it -- that is, if two things are equal, then they have equal hash codes. Most (all?) classes in the standard packages should satisfy that.
OK--but I won't be using my objects directly as keys so I don't need to worry about that. The one thing though is that the hashCode of the Integer will then be scrambled and scaled so as to be suitable for an actual hash key, right?
Right. I think you can look up the actual function it uses in the documentation. (what I presume you mean by "Scaling" is done in the hash table itself)
There are fast MD5 implementations available. Combine that with toString function to MyObject and i think you can get something what you are looking for.
-- AI
Actually, if this is all true, then probably the simplest thing is to implement hashCode for my objects and then use them as keys for themselves. Thanks
It doesn't seem to be working. I have a class CubeState, and defined the hashCode for that as hashCode(this.toString()); Then I do
Code:
HashMap<CubeState, CubeState> hm = new HashMap<CubeState, CubeState>(100000);
if(!hm.containsValue(ctmp))
	hm.put(ctmp, ctmp);
(ellipses indicate missing code, and ctmp is a CubeState)
The problem is that this is incredibly slow. I have two versions of the program, one that's like above and another that is exactly the same except I've commented out those three uses of hm and the curly braces. The one that does not use the hash map takes a few milliseconds to do what the one that does use the hash map takes a few minutes to do. Each time I do that thing, it requires less than 10000 iterations of the code that checks for membership in the hash map. In theory the hash map should make it more efficient; in practice it's ridiculously slow. I've tried using a faster-calculated hashCode but that doesn't change anything.
(1) I think it's generally better to let a hash table start off at its default size, rather than initializing it to something large. (though I suppose you can try it both ways)
(2) I think you want HashSet, not HashMap.
(3) Your description of hashCode makes no sense -- did you mean to say that you did something like
class CubeState {
public int hashCode() {
return toString().hashCode();
? (And have presumably overridden the toString method?)
(4) Judging from the timing behavior... is all of this code inside of a function that you call 10000 times? If so, then it's a total waste -- each time you call the function, it will create a new hash map, do all the work, store the result in the hash map, and then promptly discard the hash map! The hash map should probably be a static data member of your class.
I did try it at its default size of 16, but since I'm going to be storing a few hundred thousand things in it (or would if it were running fast enough to get them there!) I figured that increasing the size right off might save time wasted in increasing the table size dynamically.
I guess I could have used that. The API says HashSet uses an instance of HashMap anyway.
class CubeState {
Yes. (Actually I happened to call it cubeString instead of overriding toString but same idea) I needed a string representation of certain essential features of the CubeState anyway, and the string happened to contain exactly the same features that I wanted to use to differentiate between different CubeStates. So it was convenient.
No, the lines except for the first are within a loop, and the first line is outside the loop. The function this stuff is in is called once.
Then I don't think I could guess what's going on unless I saw the code. (Since I doubt your cubeString() method is -that- inefficient...)
You didn't accidentally comment out the part of the program that was doing the work, did you? :smile: I've done that before. :frown:
Well, thanks--when I replace the HashMap with a HashSet it's fast again. I still don't know how to use the HashMap though.
HashMap and HashSet are two different things in terms of Data Structures.
A Set is similar to that of a Mathematical Set namely you have a list of objects but there are no duplicates and the order in which the objects were inserted is generally not perserved.
On the other hand a Map could be consider as a "set of mappings between keys and values". Namely a key has an associated object.
Sorry for a fruit, toaster, color example but as Map goes this came to my mind. Consider that you wan't to have stored a set of Persons and their favorite colors, one way to do that is ofcorse create a Person class with a field favorite Color but you can might as well create a Map that is you Map a Key (Person) with a specific Value (e.g. Color). Put into code
notice in documentation HashMap<K,V> - > Key, Value pair
HashMap<String,Color> hm = new HashMap<String,Color>();
hm.put("John, Doe", Color.WHITE);
hm.put("George W Bush", Color.RED);
There you can access the color as such
Color color = hm.get("John, Doe");
notice this is a Hash Map, Hash just means that we will use HashCode as a means of organizing and accessing the mapping, you can read more about that in almost every tutorial on Data Structures.
Now a Set is a different story, you have no Key-Value pairs you just have a "list" that has no duplicates and the order doesn't matter, now you would ask why use HashSet and not ArrayList? Well generally speaking HashSet is more performant that a plain ArrayList due to the internal organisation of data.
I would recommend you a book called BigJava if you can find it in your local library(other-wize it is too expensive) it is worft it to read it, there is also a superb chapter on Collections in the Core Java II book, here
http://www.phptr.com/articles/article.asp?p=368648&rl=1 but might a be a bit to heavy for the first read.
Incidentally, I looked up a Java HashSet implementation. It seems that a difference between the way I was using HashMap and the way HashSet uses HashMap, is that I was doing a containsValue() check and HashSet does a containsKey() check on its internal HashMap. This may account for the performance difference, though it doesn't make total sense to me why it should.
Ye gads, that would do it. "containsValue" has to do a brute force search through the entire HashMap until it finds the desired value or reaches the end. And since you initialized it to have a very large capacity...
Yeah, I guess. It's kind of annoying that they have a containsValue() method in the first place when there's no efficient implementation behind it! It should be marked "deprecated."
It makes sense from both a consistency and convenience viewpoint: every other container class (even ArrayList, for example) implements a contains(Object) method. And searching for a value is something one would sometimes want to do. Map.values().contains(Object) is awkward syntax, and probably execlutes more slowly for most Map types. Some Map classes might even have efficient value lookups, and it would be a shame to force the user to break the container abstraction to access such a useful method.
Well, if someone needs a hash table then chances are they have thousands of values and they want whatever they are doing to be fast. A linear search in that situation is not practical. values().contains() at least makes the programmer aware of how inefficient it is--it's awkward and should be awkward. In terms of consistency, HashMap does have a containsKey() method, and it does not have a plain contains() method anyway (and shouldn't because it would be ambiguous). One contains-like method would be enough. In the API there isn't even a warning about the time complexity of containsValue() and the documentation is fairly vague about what's actually going on there. As you say, there could be alternate implementations that do have fast lookup for values. It should mention that this is not one of them. Deprecating this particular method in this particular class would be sensible--it is a good idea to deprecate linear time access on a likely large set, or at least mention it in the API.
