How Does Water Affect Pressure Changes in Sealed Tanks with Varied Volumes?
  • Thread starter Thread starter Jonny_trigonometry
    Thermodynamics
The discussion revolves around how the presence of water in a sealed tank affects pressure changes when a valve is opened to connect it to another tank at a lower pressure. Participants explore the implications of vapor pressure, temperature changes, and the dynamics of airflow between the tanks, considering both scenarios with and without water in the tank.
  • One participant asks how water in a sealed tank affects pressure when a valve is opened to a lower pressure tank, considering vapor pressure and temperature changes.
  • Another participant notes that the equilibrium vapor pressure of water limits the lowest pressure above the water and suggests that if the volume of the tanks is significantly larger than the volume of water, the loss of liquid water to vapor can be ignored.
  • A participant provides specific volume ratios and clarifies that the valve is positioned to prevent water flow, expressing uncertainty about incorporating vapor pressure into the equilibrium condition.
  • One participant redefines the problem context, focusing on detecting small leaks in a test tank and questioning the effect of water on airflow due to temperature changes.
  • Mathematical formulations are proposed using the Clausius-Clapeyron equation to calculate pressure changes in the presence of water and compare them with changes in the other tank.
  • Another participant points out a potential error in the units used in the calculations, suggesting that the number of water particles should be considered instead of moles.
  • A suggestion is made to use Antoine's equation for more accurate vapor pressure data.
  • One participant expresses confusion about calculating the fraction of water molecules in a gaseous state compared to those in a liquid state under specific pressure conditions.
Participants express various viewpoints on the impact of water on pressure changes, with some agreeing on the importance of vapor pressure while others raise questions about the calculations and assumptions made. The discussion remains unresolved with multiple competing views and uncertainties present.
Participants highlight limitations in their assumptions, such as the dependence on volume ratios, the positioning of the valve, and the accuracy of the mathematical models used. There are unresolved questions regarding the calculations of pressure changes and the behavior of water in different states.
This discussion may be useful for individuals interested in fluid dynamics, thermodynamics, and the behavior of gases and liquids in sealed systems, particularly in contexts involving pressure changes and vapor dynamics.
Jonny_trigonometry
How does an amount of water inside a sealed tank affect a change in pressure of the tank if you open a valve that connects the tank to another tank at a lower pressure and twice the volume? We have to consider the problem with and without water in the tank. We have to consider the vapor pressure of the water, and the fact that when pressure is reduced in the tank, more water will turn to vapor in order to reach the vapor pressure. The initial difference in pressure between the two tanks is lower than 10 psi at max. The temperature of the two tanks may change a little, but we can assume that it is constant over a long period of time.
I'm trying to figure out how to formulate the question and then answer it. Does anyone know how to work this problem? Is anyone familiar with accounting for vapor pressure in problems like these? Ultimately, I'd like to figure out the difference in final equilibrium pressures between the cases of (1) an amount of water in the tank and (2) no water in the tank.
Chemistry news on Phys.org
The lowest pressure that you can have above the water at any temperature is the equilibrium vapor pressure of water at that temperature (look up vapor tables for water). Unless the volume of the tanks is large (> 10X) compared to the volume of water, you can ignore the loss of liquid water to vapor. Do you have a rough value for this ratio of volumes? Also, is the valve connecting the tanks located at the bottom (i.e., only permits water flow, but not vapor flow)?
The equilibrium condition is that the total (gauge + vapor) pressure at the valve be the same from both tanks. In the limit of negligible liquid loss (to vapor), you can write the gauge (liquid column) pressures as a function of the level, and you can also calculate the vapor pressures simply from the ideal gas relation, using the initial pressures. There is no need to worry about partial pressures of water vapor.
hmm... Well the ratio is much greater than 10X--Vtank/Vwater--the volume of the tank is about 1.5*.08*2.5 m^3 = .3m^3, and the volume of the water is about 100ml at most, so Vwater is about .0001 m^3, so the ratio is about 3000. The valve is high enough so that no water will flow to the other tank. I do appreciate your response, and I wasn't sure how to incorporate the vapor pressure into the equilibrium condition, so you just add the pressures?
I've rethought the problem some more, and I think that I may have formulated the problem incorrectly to begin with; the scenario is very similar though. To start, the point of this setup is to detect very small leaks in a test tank (tank B), by measuring airflow from a non-leaking tank (tank A).
The problem is that there is water in tank A, and this tank is connected to a sensor that will test for air flow between the tank and another tank (tank B) at twice the volume of tank A. There is no water in tank B. Initially, the pressure is equalized between the tanks by a bypass valve, which is then shut off when data taking begins. Now, suppose both tanks don't leak. What effect does the water in tank A have if the temperature changes? Will there be an airflow between the tanks? The sensor is very sensitive, and can detect as small as a cubic millimeter of airflow. Now, if airflow is detected due to the water changing phases, this could be a false positive for a leak detection. So, I think this is the main problem, and I hope this is a much more clear problem to work through. I suppose the best way to approach this is to figure dP/dT in tank A, and compare with dP/dT in tank B.
Initial pressure of tanks = 20 psi.
water in tank A = .0001 m^3.
Volume of tank B = 2*tank A.
Max temperature change = 18 to 30 degrees Celsius.
I was thinking of using the Clausius-Clapeyron equation
[tex] \frac{dP}{dT} = \frac{L}{T \Delta V} [/tex]
where [tex]\Delta V = V_{gas} - V_{liquid}[/tex] and L is the latent heat of vaporization for water.
for calculating a change in pressure in tank A, and then comparing that with the change in pressure in tank B due to temperature changes. So, I think I'd rather do things in integral form... first off, we can make the approximation that [tex]V_{gas} \gg V_{liquid}[/tex]
[tex]dP = \frac{L}{T V_{gas}} dT[/tex]
Then using the equation of state
[tex]PV = NRT[/tex]
[tex]NR \frac{dP}{P} = \frac{L}{T^2} dT \rightarrow NR ln \left( \frac{P_2}{P_1} \right) = L \left( \frac{1}{T_1} - \frac{1}{T_2} \right)[/tex]
[tex]\rightarrow P_{2_A} = P_1 exp \left( \frac{L}{N_w R} \left( \frac{1}{T_1} - \frac{1}{T_2} \right) \right)[/tex]
Where [tex]P_{2_A}[/tex] is the final pressure of tank A and [tex]N_w[/tex] is the number of moles of water. So, if [tex]V_{w} = 100 cm^3[/tex] and [tex]\rho _{w} = .997 \frac{g}{cm^3}[/tex], then [tex]m_{w} = 99.7 g[/tex]. The molar weight of water is [tex]\simeq 18 \frac{g}{mol} = M_{w}[/tex], so [tex]N_{w} \simeq \frac{m_w}{M_w} = \frac{99.7}{18} = 5.54 mol[/tex]. Given that [tex]L \simeq 42 \frac{kJ}{mol}[/tex], and [tex]R = 8.31 \frac{J}{mol K}[/tex], we get
[tex]P_{2_A} = 20 psi exp \left( \frac{42000}{5.54*8.31} \left( \frac{1}{291} - \frac{1}{303} \right) \right) = 22.644 psi[/tex]
Now, we need to compare that with the pressure change which occurs in tank B for the same temperature change. Using the equation of state, and noting that V and N are constant in this tank, we get
[tex]\frac{P_1}{T_1} = \frac{P_2}{T_2} \rightarrow P_{2_B} = \frac{T_2}{T_1} P_1 \rightarrow P_{2_B} = \frac{303}{291} 20 psi = 20.82 psi[/tex]
so [tex]P_{2_A} - P_{2_B} = 1.82 psi[/tex]. Am I doing this right?
hmm... The units aren't right in the exponential argument, I think that N should actually be the number of water particles, so instead of 5.54, it should be 5.54*6.02*20^23. If this is the case, then the change in pressure due to water is negligible.
thanks, any help is much appreciated. I still haven't been able to satisfy myself with the answer. I don't understand how to calculate the fraction of water molecules in a gaseous state to those in a liquid state under 20 psi of regular (dry) air.
  • · Replies 26 ·
  • · Replies 24 ·
