Conservation of Angular Momentum Using the Hamiltonian
The discussion centers on the conservation of angular momentum using the Hamiltonian framework in classical mechanics. The Hamiltonian is defined as H = 1/(2m) * |p^2| - V(r), where p represents momentum and V(r) is the potential energy. The key conclusion is that the angular momentum vector L = r x p is conserved, demonstrated by the equation dL/dt = {L,H} = 0. Participants emphasize the need to compute the Poisson bracket {L,H} to prove this conservation law.
  • Understanding of Hamiltonian mechanics
  • Familiarity with Poisson brackets
  • Knowledge of angular momentum in classical mechanics
  • Basic concepts of central force fields
  • Study the derivation of the Hamiltonian equations of motion
  • Learn how to compute Poisson brackets in classical mechanics
  • Explore the relationship between Hamiltonian and Lagrangian formulations
  • Investigate the implications of conservation laws in physics
Students and educators in physics, particularly those focusing on classical mechanics and advanced topics in Hamiltonian dynamics.
physics2018
The Hamiltonian for a particle mass m, moving in a central force field is given as: H = 1/(2m) * |p^2| - V(r). Take the Hamiltonian to be invariant, such that it can be shown that L = r x p the angular momentum vector is a conserved quantity: dL/dt = {L,H} = 0.
q_i-dot = dH/dp_i and p_i-dot = - dH/dq_i
I do not understand how to go about solving the following problem ( I think I understand what the Hamiltonian is, but I do not understand how to from it to what needs to be proven) To solve the problem I believe I need to get from Hamiltonian's equations to Lagrange's p_i = dL/dx_i-dot and then from there use p-dot * dr + p * dr-dot = 0 where dr is defined as the distance between two vectors r and r+dr.
Hi physics2018, welcome to PF!:smile:
Well, since you are asked to show that [itex]\frac{d\textbf{L}}{dt}=\{\textbf{L},H\}=0[/itex], why not start by computing [itex]\{\textbf{L},H\}[/itex]?
