Marx Generator Circuit Properties?
The discussion focuses on the operational characteristics of Marx generator circuits, specifically regarding resistor values and the potential substitution of spark gaps with normally open (N.O.) relays. Resistors must balance high resistance to block current during discharge with low resistance for rapid capacitor charging, adhering to the RC time constant principle. Additionally, using N.O. relays is feasible if they can close within hundreds of nanoseconds and withstand high voltages and pulsed currents, although concerns about relay lead damage during discharge are noted.
  • Understanding of RC time constant in electrical circuits
  • Knowledge of high-voltage components and their specifications
  • Familiarity with Marx generator circuit design principles
  • Experience with relay operation and specifications
  • Research optimal resistor values for capacitor charging in high-voltage applications
  • Investigate the specifications and performance of N.O. relays for high-voltage use
  • Study the effects of rapid discharge on relay components and alternatives
  • Explore advanced Marx generator designs and their applications in electrical engineering
Electrical engineers, high-voltage circuit designers, and researchers interested in Marx generator technology and its applications in energy discharge systems.
wil3
Hello. I have several theoretical questions about Marx generator circuit operation. Note that I am in no way attempting to build one of these, as I would surely never compromise the integrity of this board by intending to build such a risky device.
I am curious about the recommended value of the resistors in the circuit. I understand that these resistors must have a high enough value so that they effectively block current during the discharge cycle, but simultaneously they must have low enough values that the capacitors can charge relatively quickly. Is there a "rule of thumb" for the optimum resistance given a certain capacitor value? I would like to minimize resistance so as to abet faster charging, but I am unsure of how low I can go without interfering with the discharge process.
Also, I am wondering whether the spark gaps may be substituted with N.O. relays in order to provide more control over the discharge timing. Would this setup save energy, or is it unrealistic because of the damage the discharge would do to the relay leads?
Thank you very much for any input.
The resistors must be chosen based on charging RC time constant, and power (I-squared R) losses during rapid charging. If you can find NO relays that close in 100's of nanoseconds, and can hold off 1000's of volts and carry pulsed currents of 1000's of amps, use them.
Bob S
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 26 ·
