I need some help with this project (optics and lens design)
  • Context: Graduate
  • Thread starter Thread starter Warsaw
    Design Lens Project
The discussion centers on modifying a camera system to focus an image on a 15mm film plane instead of the current 120mm. The required focal length (X) must be at least 60mm. Participants suggest that while adding lenses can alter the focal length, it is possible to achieve the desired image size by using only the central 15mm of the current image. The feasibility of this adjustment depends on the specifications of the additional lenses used.
  • Understanding of lens optics and focal lengths
  • Knowledge of camera systems and image planes
  • Familiarity with lens design principles
  • Experience with optical calculations and adjustments
  • Research lens combinations for achieving specific focal lengths
  • Explore optical design software for simulating lens configurations
  • Learn about cropping techniques in optical systems
  • Investigate the impact of lens diameter on image quality
Optical engineers, camera designers, and hobbyists interested in lens design and image optimization techniques.
Warsaw
The diagram below is not to scale. I'm trying to add a lens (or lenses) behind the one shown in this camera so that I can focus the image on a film plane of 15mm, rather than the current 120mm (Y). The focal length (X) needs to be at or greater than the current 60mm. What would the specifications be of a lens to accomplish this? Is it possible?
Thank you in advance for any help you can provide!
Science news on Phys.org
If you have a chosen focal length then the size of the image is already fixed.
You can add extra lenses but that changes the focal length.
Or you can also chose to only use the central 15mm of the image
It's not a problem if I have to change the focal length. Shrinking the 120mm image down to 15mm is my goal here.
  • · Replies 58 ·
9K
  • · Replies 24 ·
  • · Replies 40 ·
  • · Replies 17 ·
