Supplying Power To A Mullard Vacuum Tube
To supply power to a Mullard vacuum tube, specifically the EL-34 pentode, one must generate an electron beam by applying the correct voltage and current. The maximum plate current for the EL-34 is 100 mA with a maximum plate voltage of 250 V. Proper biasing is essential, as the difference between the maximum supply voltage and the anode voltage accounts for the cathode bias resistor IR drop. Refer to the Mullard datasheet for detailed specifications and guidelines.
  • Understanding of vacuum tube operation principles
  • Familiarity with Mullard EL-34 specifications
  • Knowledge of cathode biasing techniques
  • Experience with high-voltage power supply design
  • Study the Mullard EL-34 datasheet for detailed electrical characteristics
  • Research high-voltage power supply design for vacuum tubes
  • Learn about cathode bias resistor calculations and applications
  • Explore audio amplifier design using vacuum tubes
Audio engineers, hobbyists building vacuum tube amplifiers, and anyone interested in the operation and application of Mullard vacuum tubes.
ScienceNerd36
How would a curious young gentleman like myself go about supplying power to a Mullard vacuum tube? I have several different types of Mullard tubes, but no idea as to how I can generate the electron beam.
P.S. If side-effects of solution include death, injury or Hannah Montana please do not post.
I had a pair of Mullard EL-34 pentodes as the final push-pull stage in a big vacuum tube audio amplifier. As I recall, the plates ran so hot that they turned red. See
http://upload.wikimedia.org/wikipedia/en/9/90/Mullard_el34.jpg
http://en.wikipedia.org/wiki/EL34
Here is a data sheet
http://www.drtube.com/datasheets/el34-philips1969.pdf
Max plate current, voltage is 100 mA, 250 V
http://www.eierc.com/rc/EL34.htm
The difference between the max supply voltage and anode voltage is the cathode bias resistor IR drop from cathode to ground.
Finally found a Mullard datasheet for EL-34:
http://www.hifitubes.nl/weblog/wp-content/mullard-el34.pdf
Bob S
  • · Replies 25 ·
11K
