How to Call Gnuplot from Fortran to Plot Data Points?
  • Context: Fortran
  • Thread starter Thread starter Abraham
    Fortran Gnuplot
To plot data points from Fortran using Gnuplot, utilize the "system" subroutine in Fortran 95. The command should be formatted as CALL SYSTEM('gnuplot'), which allows you to execute Gnuplot from within your Fortran code. This method is applicable for users operating on Windows while remotely connected to Unix machines. Ensure that Gnuplot is properly installed and accessible in your environment.
  • Fortran 95 programming knowledge
  • Understanding of Gnuplot installation and usage
  • Familiarity with the "system" subroutine in Fortran
  • Basic command line operations on Windows and Unix
  • Research Gnuplot scripting for advanced plotting techniques
  • Learn about data file formatting for Gnuplot compatibility
  • Explore error handling in Fortran when calling external programs
  • Investigate cross-platform compatibility issues between Windows and Unix for Fortran applications
This discussion is beneficial for Fortran developers, data analysts, and researchers who need to visualize data outputs using Gnuplot in a cross-platform environment.
Abraham
hello. I have a fortran code that has data points as output.
How do I get fortran to plot these data points using gnuplot?
Is there a way to call the external program from within fortran?
I am using fortran95, gfortran compiler. I'm on a windows machine, but
I'm connected remotely to the Unix machines in the lab.
Thanks,
Abraham
Technology news on Phys.org
Hi Abraham,
Try using the "system" subroutine.
Code:
CALL SYSTEM(gnuplot )
Whatever you put inside the parentheses gets passed to the command line (or terminal depending on your os.)
  • · Replies 59 ·
12K
