Scanning tunneling microscopes, physics lab
The discussion revolves around the feasibility of designing a freshman-level lab experiment using a scanning tunneling microscope (STM). Participants explore the potential for students to gain hands-on experience with STMs and how such an experiment could fit within the framework of quantum mechanics, while also considering time constraints and educational value.
  • Homework-related
  • One participant questions the feasibility of a freshman lab using an STM, citing the need for multiple instruments and the associated costs and maintenance challenges.
  • Another participant suggests that a demonstration could be more practical, where students observe the STM in action rather than operate it themselves.
  • Some participants argue that the proposed lab may not provide meaningful learning experiences, as it could be more of a demonstration than an investigation.
  • A participant recalls a positive experience using a simple STM in an advanced lab, noting that while the STM itself is not overly complicated, the setup requires skill and can be expensive.
  • There is mention of available educational STM products that could be more suitable for teaching purposes compared to research-grade instruments.
  • One participant proposes that building an STM could serve as a project for a physics society chapter, suggesting it could be integrated into a freshman lab taught by senior students.
Participants express differing views on whether a freshman lab using an STM is feasible or effective. Some believe it could be a valuable experience, while others argue it may not meet educational goals and could be more appropriate as a demonstration.
Participants highlight various assumptions regarding the complexity of STMs, the required setup, and the educational outcomes of such a lab. There are unresolved questions about the practicality of using STMs in a freshman lab setting.
This discussion may be of interest to educators in physics, particularly those considering innovative lab experiences for undergraduate students, as well as members of physics societies looking for project ideas.
diffusion
This may be a bit of a silly question, but I'm wondering if it is feasible to design a freshman level lab experiment using a STM? For example, let's say the lab is simply intended to give the students a better appreciation of how a STM operates within the framework of quantum mechanics, with the "cool" factor being that the students will produce an image of some material at the atomic level on the lab PC. Is such an experiment feasible? I suppose I'm asking in terms of time requirements - how long does it take to produce a coherent image on a PC using a STM? Say the students have 3 hours of lab time - what sort of simple experiments could be performed in this amount of time?
A freshman level lab? I don't know about your school, but here that means we would need at least 8 (plus a couple spares). The cost of the instruments (and instrument repair), combined with the level of manpower needed to maintain those instruments would seem to make it infeasible. And besides, the students would not likely learn a thing.
It would be possible to design the lab so that only one STM is required. The bulk of the lab could consist of some other component, and at the end all the students could gather around while the teacher demonstrates its use, or something to that effect. There would be some way around it.
Could you elaborate on the instrument repair and manpower? Are STMs fairly problematic?
Then it's not a lab, it's a demo.
I kinda agree with Andy. That is more of a demo, not a lab. A lab is where you are doing a particular investigation of something, and the instrument (in this case, the STM) is the tool you use to investigate that something. What you are proposing is a lesson in using a STM, which in itself isn't trivial (i.e. can someone teach the difference between the imaging aspect and the spectroscopy aspect that a STM can do?)
Zz.
I actually remember using a fairly simple STM in a lab during my last year as an undergraduate student (it was in a course called "Advanced Experimental Physics"), we prepared (scotch tape!) and scanned a graphite surface and imaged the atoms.
As far as I recall we were working in groups of 4 or 5 students.
Note, however, that it was a fairly basic STM; not a proper research instrument and it has already been set up before we arrived.
But it was a lot of fun (and I still remember doing it, more than ten years later)
The "STM part" of an STM isn't very complicated (the same is true for all SPMs), the tricky (and expensive) bits are the PLLs which requires some skill to set up.
However, there are a number of products out there intended for teaching that aren't very expensive compared to a "proper" STM so it is certainly possible to use STMs in labs.
Getting a demonstration with an STM machine would probably be much easier by taking the class to the machine itself.
Usually there are quite a few of them around the physics buildings at most universities, and you could probably convince someone to give you guys a demonstration. You would probably need to find one in a big room because all of the ones that I have had experience with (AFM specifically) are in small rooms. It really depends on how small the class is.
The system we used was similar to this one:
http://www.nanoscience.com/products/easyScan2/easyScan2_STM.html
I.e. very simple system that does not require vibrational isolation or anything like that.
Lab, demo, doesn't matter at this point. I've given zero thought as to the actual lab itself, all I'm asking is if something along those lines would be feasible.
Here's why I'm asking: I thought it might be a good idea for our SPS chapter (physics society, for those unaware) to get together and build a STM as sort of a medium-term project. But rather than just have it sit there and collect dust, I thought it might also be a good idea to then incorporate the STM into a freshman lab somehow, which could be taught by a couple of the senior SPS students (at my university, 4th year students routinely teach labs). Quantum mechanics and electromagnetism make up one semester of the first year physics class, so I thought it would be a good way to incorporate a bit of both into a fun little lab class.
  • · Replies 42 ·
11K
12K
  • · Replies 20 ·
  • · Replies 33 ·
