Is Relative Motion Evidence of a Static Aether in Orbital Physics?
The discussion revolves around the concept of relative motion in the context of orbital physics, specifically examining whether this notion supports the idea of a static aether or an absolute frame of reference. Participants explore the dynamics of a moon orbiting a planet, the forces involved, and the implications of different reference frames.
  • One participant suggests that if all motion is relative, a moon in orbit could be perceived as standing still while the planet rotates beneath it, raising questions about the balance of forces in this scenario.
  • Another participant clarifies that the centripetal force acting on the moon is indeed provided by gravity, and that the moon's velocity prevents it from colliding with the planet, emphasizing the role of gravitational acceleration.
  • A different viewpoint introduces the concept of the center of mass as the inertial frame of reference for orbiting bodies, noting that the Earth-moon system's barycenter is located within the Earth.
  • A later reply reflects on the perspectives of both the planet and the moon, proposing that each body experiences a form of mutual attraction while maintaining a fixed distance, likening it to a speedboat and a water skier.
Participants express varying interpretations of relative motion and the forces at play in orbital dynamics. While some points are clarified, no consensus is reached on the implications for the concept of a static aether or absolute motion.
The discussion includes assumptions about gravitational forces, reference frames, and the nature of motion that remain unresolved, highlighting the complexity of the topic.
alpha1714
When a moon orbits around a planet, its centripetal force is balanced against the gravity of the planet, keeping it in a stable orbit. If all motion is relative, then the moon in perfect orbit could be said to be standing still while the planet rotates under it. The major difference I see is that if the moon is 'still' while the planet rotates, there would be no centripetal outward force to balance against the planet's gravity! Wouldn't it fall into the rotating planet?
Does a moon have angular momentum even if it is considered 'still' and the planet rotates? What am I missing?
I suppose the core question here is whether or not this scenario is evidence for a static 'aether', or space-time as a fabric within which absolute motion is truly applicable. Most contemporary theories reject any 'absolute' position or motion, so I'd be interested how relative motion can account for the seeming lack of congruent forces between perspectives within the physical system.
Thanks,
-alpha1714
Astronomy news on Phys.org
Centripetal force IS the gravitational force. The gravitational force supplies the centripetal force in this scenario to keep the Moon from shooting off into space.
The reason the Moon doesn't fly into the Earth is not because the forces are balanced, but because it has sufficient velocity to escape a collision with Earth. In a sense, it is constantly falling towards the Earth, but it's "horizontal" speed is sufficient that it clear's Earth's curvature.
See this picture for example:
http://en.wikipedia.org/wiki/File:Newton_Cannon.svg
As for relative motion; since the Moon is constantly falling towards Earth, it is undergoing constant (approximately) acceleration. Thus, the Moon's reference frame is accelerated, and not inertial. Therefore, the principle of special relativity doesn't apply to the Moon. One must use general relativity to discuss these reference frames...a subject I'm not sufficiently proficient into make further discussion.
The inertial frame of reference for bodies in orbit about each other is the center of mass, or barycenter. For the Earth moon orbit, that center is located within the Earth itself. The reason for this is that the Earth is more massive than the moon. The Earth does orbit the moon, but because the center is located within the Earth itself, the Earth only appears to wobble.
Go to this wikipedia page and scroll down to the section labeled "animations".
http://en.wikipedia.org/wiki/Center_of_mass
Thanks everyone for your replies. After considering your posts and a lot of further pondering, I think I understand what I was missing.
From the perspective of the planet, it is standing still while the moon is revolving around it. From the moon's point of view, it is still while the planet spins beneath. In both cases, however, the gravitational acceleration toward each other is balanced against a feeling of opposite acceleration in exactly the other direction. From the perspective of the moon, it is falling toward the planet while the planet is moving directly away from the moon at the same speed, and vice versa. This accounts for the feeling of mutual attraction while remaining at a fixed distance. It's like a speedboat dragging a water skier behind, both always feeling the tug of attraction but remaining the same distance apart.
Thanks again for your help, keep up the good thinking.
-alpha1714
  • · Replies 86 ·
9K
  • · Replies 21 ·
  • · Replies 31 ·
