What Is the Decibel Level After Removing 69 Pigs?
  • Thread starter Thread starter bdh1613
    Change
The decibel level of the remaining pigs after removing 69 from an initial group of 176 is calculated to be approximately 70.84 dB. The initial noise level was 73 dB, and the correct approach involves using the logarithmic relationship between sound intensity and the number of pigs remaining. The formula applied is 73 - x = 10Log(176/107), leading to the conclusion that the decibel level decreases due to the reduction in the number of pigs.
  • Understanding of logarithmic functions and their application in sound intensity calculations
  • Familiarity with the decibel scale and its significance in measuring sound
  • Knowledge of the formula for sound intensity: I = P/A
  • Basic principles of sound intensity ratios
  • Study the relationship between sound intensity and decibel levels using the formula B = 10 log(Is/Io)
  • Explore examples of sound intensity calculations involving different numbers of sound sources
  • Learn about the effects of sound attenuation in various environments
  • Investigate real-world applications of decibel measurements in agriculture and animal husbandry
Students in physics or engineering, acoustics researchers, and anyone interested in sound measurement and its practical applications in environments with multiple sound sources.
bdh1613
The noise level coming from a pig pen with 176 pigs is 73 dB. Assuming each of the remaining pigs squeal at their original level after 69 of their companions have been removed, what is the decibel level of the remaining pigs?
Answer in units of dB.
I= P/A
B=10dbLog(Is/Io)
I was thinking that the ratio of the intensities would be equal to the change in the number of pigs.
73dB - x = 10Log(69)
I found that x= 54.61150909db.
However this was wrong.
I did a similar problem to this regarding people were a single person can speak at 65dB. The question asked how many people does it take to reach 78dB. In that particular problem the ratio was equal to the number of people. I think this was the case because we had a base value for what a single person could produce. In the problem with the pigs there isn't necessarily a based value for dB. Where am I going wrong in my approach? I spelled decibels wrong in the title, my bad.
SOLVED
I realized what I was doing wrong. The logarithmic is defining two intensities that are comparing values. The reason that the comparison was equal to the number of people was because that it was 20people to 1 person. In the case of the pigs the comparison is not equal to 69, rather it is equal to 176/107.This is how it looks
73 -x = 10Log(176/107)
x=70.8387111dB
9K
  • · Replies 62 ·
13K
  • · Replies 69 ·
10K
  • · Replies 17 ·
  • · Replies 21 ·
