Domain of Square Root Function: Solving Inequalities for x ≤ -2
  • Thread starter Thread starter Shaybay92
    Inequality
The discussion revolves around determining the domain of a square root function by solving an inequality involving rational expressions. The specific inequality being analyzed is 1/(x+1) - 4/(x-2) ≥ 0.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to solve the inequality by cross-multiplying and simplifying, leading to a conclusion of x ≤ -2. However, they express uncertainty about the treatment of the inequality and the implications of their solution.
  • Some participants clarify that multiplying by a negative number changes the direction of the inequality, and suggest alternative methods involving the squares of the denominators.
  • Others confirm the original poster's conclusion but question the completeness of the domain analysis, indicating that the domain may not be limited to x ≤ -2.
Participants note that the original poster may not have been taught about inequalities previously, which could affect their understanding of the problem. There is also a mention of the graph of the function, indicating potential complexities in the domain that require further clarification.
Shaybay92
I am trying to find the domain of a square root function... To do so I have to solve the following inequality:
1/(x+1) - 4/(x-2) >= 0
This is how i attempted to solve it...:
I crossmultilplied the denominator to get
[(x-2) - 4(x+1)]/(x-2)(x+1) >= 0
Multiplied both sides by (x-2)(x+1)
(x-2) - 4(x+1) > = 0
Expanded
x - 2 -4x - 4 = 0
-3x -6 >= 0
-3(x+2) >= 0
(x+2) <= 0 <---- at this point I am not sure if i swap the sign around, I haven't been taught inequalities before... but I will swap it around anyway.
x <= -2
Is this the correct answer? When I graph the entire function (sqrt of the above), I get part of the function less than -2 but also part greater than -2... I don't really understand how there can be x > -2 if I got this restriction here of >-2.
When dealing with an inequality, if you multiply by a negative number, the inequality changes.
You can deal with this by multiplying by the square of the denominator
i.e. ((x+1)(x-2))2
Yeah, when I calculate it I get the same answer:
x <= (-2)
Just as rock.freak667 said, multiply both sides by (x+1)2(x-2)2. The domain is not just x <= -2.
  • · Replies 32 ·
