How Does Hooke's Law Help Calculate Spring Length for Weight Drops?
This discussion focuses on using Hooke's Law to calculate the appropriate length of a spring for a specific weight drop scenario. The example provided involves a 1 lb weight dropped from a height of 10 feet, with the spring constant determined through experimentation. The key principle is equating gravitational potential energy (mgh) with the potential energy stored in a stretched spring, allowing for precise calculations to prevent the weight from hitting the ground.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of gravitational potential energy (mgh)
  • Basic principles of energy conservation
  • Familiarity with experimental physics techniques
  • Research how to calculate spring constant using Hooke's Law
  • Explore energy conservation principles in physics
  • Learn about potential energy equations for springs
  • Investigate practical applications of springs in engineering
Physics students, engineers, and anyone interested in the practical applications of Hooke's Law and spring mechanics.
cman
I'm trying to figure out how to determine how long a spring should be to drop a known weight a known length? For example...10 foot drop, 1 lb weight, and I pick up a flexible spring from the hardware store (spring constant to be determined by Hooke's law experimentation), should I not be able to determine how long a spring to cut to just make the 1 lb weight drop to but not hit the floor?...much like a bungee question.
Welcome to Physics Forums.
Have you learned about conservation of energy in a physics class? You can equate the gravitational potential energy mgh with the potential energy of a stretched spring.
  • · Replies 27 ·
  • · Replies 131 ·
9K
