Can I Use My Own Router with Verizon FIOS?
  • Thread starter Thread starter russ_watters
    Networks
The discussion revolves around the challenges of using a personal router (Linksys WRT160N) with Verizon FIOS while the service requires the use of their provided router (Actiontec MI424). Participants explore connectivity issues, configuration settings, and potential solutions for integrating the two routers.
  • One participant describes experiencing intermittent connectivity issues between the Linksys and Actiontec routers, where the connection drops after a few seconds.
  • Another participant suggests disabling DHCP on the Linksys router and connecting it through a standard ethernet port to avoid IP address conflicts, proposing this as a basic solution.
  • A different participant raises the possibility that the ISP may have a MAC address registration policy, recommending the cloning of a MAC address if direct connection to the Actiontec works.
  • One participant acknowledges finding a tutorial from Verizon that confirms the solution of disabling DHCP and connecting through a standard port, indicating that this approach resolved similar issues for them.
Participants express varying experiences and solutions, with some agreeing on the necessity of disabling DHCP while others introduce additional considerations like MAC address registration. The discussion remains unresolved as multiple approaches are suggested without consensus on a single solution.
Participants mention specific configurations and settings that may depend on individual setups, such as the type of ethernet ports available and the specific behavior of the routers involved. There is also mention of potential ISP policies that could affect connectivity.
I have Verizon FIOS and the service is great, but along with that service, they provide a crappy router (Actiontec MI424) that you must use. I would like to just use it as the internet connection and use my Linksys WRT160N to network my devices together inside my house. Unfortunately, they don't play nice together.
I am able to successfully establish a connection between the Linksys and Actiontec routers for about 5 seconds at a time before the connection drops. In the Linksys administration applet, I can refresh my IP address, load a website or two, then *poof*, connection gone.
Anyone have any idea why this would happen?
Computer science news on Phys.org
Right, I have a dual router setup and had similar problems.
Firstly, your 'good' router, does it have dedicated internet in ethernet port?
The basic solution I found is to disable DHCP on the second (the good) router and plug the internet in cable (the cable from the first router) into a standard ethernet port not the internet in one. This then forces the first router to distrubute the ip addresses and the second one simply acts as an extension of the first.
If you don't disable DHCP, they both try to generate IP addresses which caused problems for me.
That should solve it, if not I have a few other things to try.
Is your MAC address registered with the ISP? Some ISPs still have one-computer, one-IP policies (even though they frequently provide routers, tout the "household experience", etc. etc.) Many routers allow you to clone a MAC address--if your computer works when you plug it in directly to their router/modem/whatsit, it might be worth it to try to clone the MAC address of the computer for the router you WANT to use.
According to the website, there's an actual "Internet" uplink port, but I assume that you've got that plugged in and going to your Actiontec already (using a known good ethernet cable)?
http://homesupport.cisco.com/en-us/wireless/lbc/WRT160N
Meh, I should have searched first - Verizon had a good tutorial and this was basically the solution:
Well, I'm glad the potential for me to help you was there... :smile:
  • · Replies 25 ·
  • · Replies 27 ·
12K
