Solving Laplace Transform Homework: Equations 1 & 2
The discussion revolves around manipulating Laplace transform equations related to initial value problems (IVPs). The original poster expresses difficulty in transforming two specific equations to match standard forms from the Laplace transform table.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest various methods for manipulation, including completing the square and using partial fractions. There is a debate about the applicability of partial fractions due to the nature of the denominators.
Some participants have provided guidance on rewriting the equations and exploring the use of complex numbers in the context of inverse Laplace transforms. There is an ongoing exploration of different approaches, and while some methods are suggested, no consensus has been reached on a single effective strategy.
The original poster is working under constraints typical of homework assignments, including the requirement to manipulate equations without direct solutions being provided. There is also a focus on ensuring the results remain real when using complex algebra.
popo902
Im having trouble finding ways to manipulate equations to fit something from the table
The two I'm stuck on are these
1. [itex]\frac{1}{s^{2}- 2s + 3} (\frac{1+(s^{2}+1)e^{-3\Pi S}}{(s^{2}+1)})[/itex] = Y(s)
2.[itex]\frac{1}{s^{2}- 2s + 2} (\frac{s}{s^{2}+1} + s - 2)[/itex] = Y(s)
These are the IVPs i got them from
1. y" - 2y' + 3y = sint + [tex]\delta[/tex](t - 3*pi)
y(0) = 0
y'(0) = 0
2. y'' - 2y' + 2y = cost
y(0) = 1
y'(o) = 0
I tried all sorts of things like multiplying the equations out
i still can't seem to find a way to comfortably manipulate it to match anything on the laplace table
can some one help or give me a tip?
The first thing I would recommend to do is write:
[tex] s^{2}-2s+3=(s-1)^2+2,\quad s^{2}-2s+2=(s-1)^2+1[/tex]
Then I think the transform looks like a convolution doesn't it?
Use partial fractions to break them up.
You can't use partial fractions here.
Yes, you can. Some of the denominators remain quadratic in s if you restrict yourself to reals, but can be fully expanded out to linear factors if you use complex roots.
RGV
I see i see
but how did you get the equations to look like that?
and could you get the inverse laplace transforms with complex numbers??
popo902 said:
I see i see
Do you mean what hunt_mat did? If so, he just completed the square.
Yes, you can, but it's usually best to avoid that if possible. Sign mistakes are bad enough, but when you start throwing factors of i around, you increase your chance of making a mistake immensely. You can definitely invert the transform without resorting to using complex algebra.
yeh i saw that after about 30 minutes of just staring at the problem haha
however, when you do carry j's into your laplace and get the inverse, they will still be complex right?
so technically you could have a laplace shifted by a complex value using the e^at rule, where a = some j?
thank you all though, it really helped
If you do everything correctly using complex algebra, it will simplify down to a purely real result. In other words, the math is consistent. If it doesn't come out real, you made a mistake somewhere.
