First law of thermodynamics applied to a submarine
The discussion focuses on applying the first law of thermodynamics to calculate the average temperature of air in a submarine after one hour of diving. The submarine contains 1000m³ of air at an initial temperature of 15°C and pressure of 0.1MPa. A heat flow of 60 MJ/h and dissipative work of 21 kW are considered, leading to a calculated temperature increase of approximately 10K to 14K, depending on whether a constant-volume or constant-pressure process is assumed. The specific heat capacity of air is utilized in the calculations, with the specific heat at constant volume derived from the relationship between Cp and Cv.
  • Understanding of the first law of thermodynamics
  • Knowledge of specific heat capacities (Cp and Cv)
  • Familiarity with gas laws and properties (e.g., ideal gas law)
  • Basic skills in thermodynamic calculations
  • Study the derivation and application of the ideal gas law
  • Learn about the differences between constant-volume and constant-pressure processes
  • Explore the implications of heat transfer in closed systems
  • Investigate the specific heat capacities of different gases
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in submarine design or thermal management systems.
Carbon884
Hallo,
I hope someone can help me with the following question:
A submarine conatins 1000m^3 of air and has a temperature and pressure of 15°C and 0.1MPa respectively. Due to the cold seawater a heatflow of 60 MJ/h occurs. The machines on the otherhand adds disspiative Work of 21 kW to the system. The specific heat capacity of air is c(p,air) = 1.005 kJ/Kg*K.
what average Temperature will the air have after one hour of diving?
V=constant=1000m^3
P=constant?
T1=288.15K => T2=?
Firstly i found the density and mass of the gas:
R(air)= 286.9 J/K*Kg => density= P/T*R(air)=1.209 Kg/m^3 => m= V*density= 1209.63 Kg
Secondly i found the total Energy:
Q/h=Wdiss - Q/h = 15600 KJ/h
Then i used the first law:
dW=0 because V=constant
dQ=dU
Q=mcp(T2-T1)= m(R(air)-cv)*(T2-T1)= 288.19K ... which can't possibly be right because that is essentially my T1 temerature. So what did I do wrong?
Thanks for your help in advance ^^.
Science news on Phys.org
R(air) = Cp - Cv
=> Cp=R(air)+Cv
so, Q=m(R(air)+Cv)(T2-T1)
The specific heat at constant pressure is given in the problem.
If you assume a constant-volume process, you can calculate cv=cp-R.
Either way the temperature increase is of the order of 10K (around 14K if you consider constant volume).
Review your last step.
  • · Replies 40 ·
