Can Simple Mass Accretion Turn a Neutron Star Into a Black Hole?
The discussion centers on whether simple mass accretion can transform a neutron star into a black hole, or if such a transformation necessitates specific temperatures and pressures associated with the collapse of a massive star. The scope includes theoretical considerations, mass limits, and observational data related to neutron stars and black holes.
  • Some participants propose that if a neutron star accretes enough mass, it will become a black hole, suggesting that temperature and pressure are relevant primarily in how they affect density.
  • Others argue that pressure plays a critical role in the collapse of neutron stars, contributing to the stress-energy tensor and influencing the conditions under which collapse occurs.
  • A participant questions the mass ranges for neutron stars and black holes, seeking estimates for the solar masses required to form each type of star.
  • Concerns are raised about the upper mass limit for neutron stars, with some suggesting it is around 1.97 solar masses, while black holes appear to start at around 3 solar masses.
  • There is speculation about the possibility of neutron stars collapsing at around 1.99 solar masses and whether many black holes remain unobserved due to their mass accumulation behavior.
  • Participants inquire about equations or estimates for the mass of unobserved neutron stars and black holes based on current observational data.
  • One participant asserts that neutron stars do collapse into black holes during type Ic supernovae, while another challenges this claim, seeking references and expressing uncertainty about the classification.
Participants express differing views on the mechanisms and conditions necessary for neutron stars to become black holes, with no consensus reached on the role of mass accretion versus temperature and pressure. The discussion remains unresolved regarding the specifics of mass limits and the classification of supernova events.
Limitations include uncertainty about the exact mass limits for neutron stars and black holes, the definitions of supernova types, and the observational data regarding the number of nearby neutron stars and black holes.
tvscientist
Can simple mass accretion turn a neutron star into a Black Hole, or does a BH require temperatures and pressures from the collapsed massive star?
Astronomy news on Phys.org
If a neutron star accretes enough mass it will become a black hole. Temperature and pressure are only relevant to the extent that they affect the density.
Mathman
Thanks for the response. If mass accumulation can turn a neutron star into a BH, then a neutron star has both a lower and higher range of total mass. Do we have estimates of the total solar masses required to 1) produce a neutron star instead of a white dwarf; and two, turn a neutron star into a BH?
The theoretical upper mass limit for a white dwarf is the Chandrasekhar limit ~ 1.44 solar mass. Neutron stars have varying mass ranges. Most are between 1.2 and 1.4 solar mass, with a select few are in the 2 solar mass range. The theoretical upper limit is not known with any certainty, but, believed to closer to 2 solar masses than 3.
A great question; it will probably be resolved this decade. Possibly simple mass accretion can't turn a Neutron Star Into a Black Hole. Of the roughly 2000 observed neutron stars, none seems to have a mass greater than about 1.97 solar mass. Of the about 20 nearby observed black holes, the smallest seems to be at least 3 SM, and more probably 5 SM. Possibly a surface effect or more likely a core effect could be limiting the upper mass limit of neutron stars.
Well that's not true. Remember pressure contributes directly into the stress energy tensor, and this is actually important for neutron star collapse. Since as the star collapses the pressure increases, it actually fuels the runaway collapse after a certain mass 'tipping point' has been reached.
There remains a serious question about the lower mass limit for black holes. Hardly any suspects are less than several solar masses. There should be many more if our stellar evolution models are correct - although it could be a detection limit thing.
On the other hand maybe neutron stars do collapse at about 1.99 SM. Could there be a lot more relatively nearby black holes that we just don't see because they have gobbled up all the nearby matter in their sphere of influence? Larger stars apparently gobble up nearby stars much faster because the relativistic gravity makes the orbits unstable.
Is there an equation to estimate the mass of unobserved neutron stars from the total mass of the about 2000 presently observed nearby neutrons stars? Is there a similar estimate for black holes?
"There should be many more if our stellar evolution models are correct ."
Solving this might lead to an answer. I think the figures presently are that there are about 2000 observed "nearby" neutron stars and about 20 observed "nearby" black holes, where "nearby" is within roughly 10,000 light years from earth. (Are these numbers correct?) 20 seems like too small a number, even taking into account that he average mass of these black holes is much more than the average mass of neutron stars. Might this be because over time the local nearby black holes have already swept up a greater percentage of their nearby material compared to neutron stars, and hence a greater percentage of these black holes are not observed?
Do you have a guesstimate of how many "nearby" black holes should be observed?
All neutron stars measured so far -- not very many -- have a mass between 1.4 and 1.97 AU(mass of Sun.) The smallest measured black holes are 4AU. The significance of this gap is not yet understood.
It IS known that neutron stars do collapse into black holes. It is called a type Ic supernova. They are rare but useful since each such collapse releases the same amount of energy, so it can be used as a "standard candle" to determine the distance to a galaxy.
"It IS known that neutron stars do collapse into black holes. It is called a type Ic supernova."
Are you sure about this? Do you have an internet reference that says this?
I recall reading that but don't recall where. A search turned up nothing, so my statement appears to have no foundation. It appears that a Ic is a supernova with no silicon or carbon absorption lines. A neutron star collapse would qualify, but that is not what it is generally believed to be.
  • · Replies 48 ·
  • · Replies 87 ·
11K
